High Rev
Old Mar 10, 2009 | 10:10 AM
bpmohr's Avatar
bpmohr
Stage II
Default High Rev
Over the last couple of weeks I did some upgrades and preventive maintenance on my 2003 883 Sporty. I did an oil change, new plugs (screaming eagle), forward controls and installed a screaming eagle air cleaner. I noticed now, and maybe it should be this way, that it seems to rev higher when I pull back on the throttle, like I need to upshift (even in 5th) but levels off. Is this normal, is my bike just running better than I am used to? It was a dog before. One more note, it had the California stock air cleaner on it before, I ripped that crap out, I don’t live in Cali.
Thanks,
Brian
Old Mar 10, 2009 | 11:14 AM
mbwannabe1's Avatar
mbwannabe1
Unless the clutch is slipping from increased torque, the revs shouldn't be any different. The gearing, pulleys and tire size are all still the same. It might be that your perception of RPM is different because the sound will change with a better breather.
If the clutch is slipping, you need to take care of it right away. There isn't much lining on the plates to start with, and they'll burn up quick if slipping. Did you adjust the clutch and/or change primary fluid during the preventive maintenance? What are you using for primary fluid?
Old Mar 11, 2009 | 09:59 AM
bpmohr's Avatar
bpmohr
Stage II
Hmm, I also did put new clutch and brake levels on the bike. So I did adjust the clutch cable. I will have to check that. As for the primary oil. I have not check that since I purchased the bike. Something else I should do. Thanks for the help.
Old Mar 11, 2009 | 10:22 AM
scotty-j's Avatar
scotty-j
incase you overlooked something when adjusting the cable, check out this great write up on cable adjustment...see post #4 for his illustrated how-to http://xlforum.net/vbportal/forums/s...ad.php?t=49376
Old Mar 11, 2009 | 01:05 PM
Zimbob's Avatar
Zimbob
She is breathing better. I would re=check the clutch cable to make sure it's right, other than that, enjoy your new found HP.
Gato1
Jan 10, 2012 12:25 PM
reds_racing
Feb 18, 2010 06:45 PM
cdsgunn
Aug 20, 2009 11:36 AM
quackhead
May 6, 2008 12:14 PM
dynamac
17
Aug 1, 2005 01:01 PM
