coil relocation
Old Mar 10, 2009 | 06:13 PM
1200efi's Avatar
1200efi
Question coil relocation
I did a search on coil relocation, and can't find what I'm looking for. I need to know what terminal ends the guys or gals used for the coil end of the spark plug wires. I have not seen this type of end before, does not come in any kits I have checked. The inside of the coil tower is a small post (about 1/8 inch round) and the end on the wire terminal has a 1/8 inch hole with an E clip on it. I need some of those ends. Most likely it's just on the EFI models. Been to the stealers and they just laughed at me and wanted to sell me a new set of wires. Been to NAPA, Autozone, etc,etc, nobody has them around here. Hope somebody can help me. I have an 08 1200C. Trying to make up a new set of wires that I like. Thanks. Ride safe.
Old Mar 10, 2009 | 07:43 PM
Yatez004's Avatar
Yatez004
Buy a set of stock Rocker C wires. It would be cheaper and quicker to throw those on
Old Mar 11, 2009 | 03:55 AM
1200efi's Avatar
1200efi
Hi, Still looking for some help with the terminals. Thanks Ride safe.
Old Mar 11, 2009 | 04:33 AM
Austen's Avatar
Austen
what exactly are you looking for? im confused. did u relocate ur coil between the rocker boxes? then all you need is another short wire, available at any dealer
Old Mar 11, 2009 | 08:00 AM
Gpsjr10's Avatar
Gpsjr10
we need pics please
Old Mar 11, 2009 | 04:37 PM
Yatez004's Avatar
Yatez004
Hes looking for the end that plugs into the coil to keep it from ratteling out. Take the boot off your coil and look at that end that plugs into it. Its like a clip type because of the vibration. Its different from a car. Your not going to find that end. Buy a set of wires or push the boot off and take that end off from your stock wires is all I can tell ya.
Old Mar 11, 2009 | 05:33 PM
1200efi's Avatar
1200efi
Thank you Yatez004, you know exactly what I'm looking for, I can't believe there are no ends around. I guess I'll have to cut up a new wire. Ride safe.
Old Mar 11, 2009 | 06:18 PM
christner's Avatar
christner
Default Spark plug wires
I relocated mine to between the Vee, had a helluva trying to find wires. I went to a total of 6 places, including some custom speed shops. I ended up buying a Screamin Eagle set for an '06, non EFI, cut them down and reused the existing ends. It was very tedious. I would recommend looking online. Try MSD maybe.
Old Mar 11, 2009 | 07:44 PM
NightsterTexas's Avatar
NightsterTexas
That's what i ended up doing. Bought the same set. Pain in the #$%!!!!
Old Mar 12, 2009 | 05:23 PM
1200efi's Avatar
1200efi
Thanks guys for the help and advice. Ride safe.
