Options For Bobbed Fender Struts?
The bike I bought has the rear fender already bobbed, and a custom-made sissy bar with fender and signal light mounts built in - a one-piece deal. I'm not loving the sissy bar and would probably need to add fender struts to change it out, but I'm pretty sure the stock fender struts/covers will be too long.
I'm not sure what the frame part of the struts looks like, but I think the fender will attach there - of course it won't be very sturdy in that case.
So what have you guys done in this situation? Any aftermarket solutions you've heard of or used?
Debrix has stock strut covers.
http://stores.channeladvisor.com/deb...XL%20Sportster
After that not sure way you are looking for without seeing pics of current setup.
From the pics, can anyone see a reason why removing the sissy bar would remove any fender mounting options?
The whole thing:
Closer look at the strut:
And one more:
It looks like the sissy bar/strut combo is held on only with the signal mount bolts (the signal shaft "ears" are welded onto the strut). Since I haven't disassembled anything yet, I don't know if there are even forward mounting bosses underneath the "ears" on the chrome struts. Obviously, nothing's attached there.
Mostly what I'm asking is what I will need on hand to reassemble once I remove the sissy bar. Looks like I have some great fender struts after all, and that I'll need some different turn signal options - which should mount through the same holes that already exist, no?
P.S. icecaps, nice looking bike! Your rear fender is a bit longer than mine, and it looks like it was cut off with the stock fender struts in mind.
Thanks for the input.
