shifter doesn't work?
Old Apr 28, 2006 | 09:17 PM
02Sporty1200C's Avatar
02Sporty1200C
Default shifter doesn't work?
Hey all,
Question is.....i got all the cables done and everything back together......cleaned it all up.....started it up....went to put into gear.......and the shifter went right past first gear....so, i pulled it back and it went right past second gear.....now it seams to me that something is broken because the shifter doesn't stop when it's in gear it goes past the gear........what could this be and where do i start
Old Apr 28, 2006 | 10:24 PM
02Sporty1200C
Default RE: shifter doesn't work?
anyone have any ideas.....i'm selling the bike and i'd like to get it back together ASAP......i want it fixed right .....just need some ideas of where to start
thanks
Old Apr 28, 2006 | 10:37 PM
Shovelhead Bob's Avatar
Shovelhead Bob
You took the primary off, right????
If that is the case, you MIGHT have dislodged the springs that hold the dog teeth against the shifter drum actuator...
Old Apr 29, 2006 | 03:33 AM
02Sporty1200C
no,
didn't take the primary cover off....just the derby cover then the spring and that first assembly to get the new cable on....
Old Apr 29, 2006 | 09:11 AM
Shovelhead Bob
Then your clutch hub and cable are out of adjustment.....
Or you could have your shifter linkage....
t059736
Apr 25, 2018 02:43 PM
Ryguy7
Jul 25, 2017 05:52 AM
Capt_Locutus
Mar 18, 2012 08:36 PM
mrtac2man
Sep 8, 2010 06:39 PM
DanDman
Sep 16, 2008 10:53 AM
