'04 883 Conversion Update
Old May 1, 2006 | 05:58 PM
steps25's Avatar
steps25
Default '04 883 Conversion Update
Hello all
I have a couple questions.
I am thinking of converting my 883C to a 1200 or 1250.
Has anyone done the conversion on a '04 or later model?
Does anyone have the names/websites of big bore kits for the '04 & later models?
I've been researching & haven't found a lot for the new engine model.
I don't mind doing the work myself, so I'm trying to get a list of big bore kits to compare.
Ideally, I'd like to find an all inclusive, reliable & affordable kit. Pistons, rings, pins, cams, jet kit, etc.
is it better to bore out the existing cylinders or go with new cylinders?? Better to use existing cylinder heads or do I need new ones?
Also, I'd like a little more top end. The RPM's get a little high at highway speeds.
Any suggestions for gearing change? Can I just change sprockets like on a motocross bike to change gearing?, (my local shop said no)
Any suggestions would be great.
Thanks
Steve
Old May 1, 2006 | 06:19 PM
boom215's Avatar
boom215
Default RE: '04 883 Conversion
My friend did it to his 04. Well actually HD did it to his 04 , all he got was the 1200 kit from them and a makuni. All i can say is dam.....
Old May 1, 2006 | 06:20 PM
LeavenworthJeff's Avatar
LeavenworthJeff
Check out ******'s Racing. Now known as NRHS. Should be able to find them on the web easy enough. They have all that you need.
LeavenworthJeff
Old May 1, 2006 | 09:27 PM
Johnny's Avatar
Johnny
Sputhe has a 1400 kit.
http://www.sputhe.com/
NRHS Performance has a 1250 and 1450 kit.
http://www.nrhsperformance.com/ekitsportster04.shtml
Old May 1, 2006 | 10:36 PM
Big Cholla's Avatar
Big Cholla
Steps: I second the suggestion to check out NRHS. They have a superb reputation and a very reasonable price on a 1250 cc conversion to the 883 engine. If I ever do a conversion to my XL883C, it will be with the NRHS kit. ............. BC
Old May 5, 2006 | 02:52 PM
steps25's Avatar
steps25
After more research I'm thinking of going this route.
Harley Cylinders
SE Pistons 10:1
S&S Carb
Sifton Cam
Thoughts? Anyone actually done a conversion on an '04 later and have details of what products they used? Gains? etc.
Old May 5, 2006 | 03:46 PM
NYSportster's Avatar
NYSportster
Do you have to break the bike in all over again when you do a conversion?
Old May 6, 2006 | 08:29 AM
blksabth666's Avatar
blksabth666
1st Gear
Im doing the same next winter,I should of just bought the 1200!There's a decent kit in j+p cycles.pick'n the right parts is critical.
Old Jun 7, 2006 | 01:36 PM
steps25's Avatar
steps25
Well I finshed the conversion.
Went with:
Harley Cylinders
Screamin Eagle high compression pistons
Andrews N2 CAMS
Vance & Hines Straight Shots
Wanted to go with the new S&S carb0-A/C but, apparently they're backordered.? Rejetted with 185 Main, 48 Slow
(got a great deal on parts from a motorcycle shop owner in my Mustang club! Couldn't pass it up)
So far so good!
Old Jun 15, 2006 | 09:11 PM
buzby's Avatar
buzby
4th Gear
let us know how it turns out. i am also considering doing a 1200 kit with hd jugs and se pistons
