Screamin eagle II diameter
Old Apr 13, 2009 | 02:15 PM
paolu79's Avatar
paolu79
Default Screamin eagle II diameter
Anybody knows the Outer diameter of the scraming eagle II for sporster? there asre different kind or just one?
Old Apr 13, 2009 | 02:57 PM
HOTLAP's Avatar
HOTLAP
The only difference between the original SEII's was the end cut (slash down, slash out) The new SE are "street performance" or SESP's and are not much better than the OEM mufflers.
Make sure there is the "II" after the screamin eagle text on the rear muffler and you know you have the good ones.
Old Apr 13, 2009 | 03:21 PM
paolu79's Avatar
paolu79
oh yes i know that, but i'd like to know the outer diameter of the Screaming eagle II just for curiosity
Old Apr 13, 2009 | 03:29 PM
HOTLAP's Avatar
HOTLAP
9 & 1/2 inches or just over 24 cm.
Old Apr 13, 2009 | 05:14 PM
tinman67's Avatar
tinman67
Default Mistake?
I think you are giving him the circumference(total around the pipe) not the diameter(total distance across the circle) although with some high school math, if I remember correctly you can take the circumference divided by Pi (3.14 something, 3.14 is close enough) and you will come out with a diameter of about 2.8"
Old Apr 13, 2009 | 05:27 PM
HOTLAP's Avatar
HOTLAP
Yes you are right, my screw up, they are aprox 2 & 3/4 inch or about 7 cm.
ripto
Feb 27, 2017 06:03 AM
DarkManC
Jan 26, 2010 03:44 PM
chadw8434
Aug 27, 2008 05:15 AM
texasridr
Aug 9, 2008 09:53 PM
1200c
Jul 21, 2005 01:58 AM
