Carb problem
Old Apr 20, 2009 | 02:44 PM
kenward's Avatar
kenward
Default Carb problem
I have put about 300 miles on my bike now and wonder if I am having a carb problem or is this typical engine response. 1997 1200 custom sportster all stock with the stock screaming eagle exhaustm with 21,000 miles. Bike starts up fine and slowly adjust when backing off choke takes a good 3-5 minutes to wean off choke. Experiences a few "chug" sounds at idle with slight reving. With easy excelleration and low RPM cruising it still does some quick "chug" noises. When cranking throttle hard it runs well. When slowing down to a stop it has had a slight backfire a few times. I am not sure is the "chug" sound becuase the bike is staving for fuel? Do all stock harleys do this? Should I run carb cleaner through the fuel or take it in to have the carbs checked or even change out the jets. As you can tell I do not know much about carb adjustments. I just changed the fliuds and changed the plugs. Plugs looked good and made no difference. Any suggestions?
Old Apr 20, 2009 | 03:15 PM
jag1886's Avatar
jag1886
If it was my 13 year old bike I would pull the carb take it apart and clean it, there could be almost anything in a carb that old and while I had it apart I would make certian it was jetted properly the slow jet should be a 45 and the main jet should be a 175 also check the rubber diaphram that pulls the slide up and down the make certian its not cracked or torn.
Old Apr 20, 2009 | 03:31 PM
RGreeves's Avatar
RGreeves
Default Pinch o' salt...
I'm no expert, but in the the spirit:
- the choke time sounds correct,
- if the 'chug' is a misfire, _and_ happens at lower revs, _and_ happens in somewhat cooler conditions, you may be okay and may just have to make a conscious effort to keep the revs up during the first 10 minutes of operation,
- otherwise you might be running lean and might consider paying for a dyno / carb adjustment (while you're at it you could get the new pipes you want).
Hopefully you will get better help than this.
Old Apr 20, 2009 | 03:44 PM
iceman336's Avatar
iceman336
Yep, sounds like the carb to me too. Sounds like a jetting issue...
Old Apr 20, 2009 | 04:13 PM
vincentostapowich's Avatar
vincentostapowich
The clue is the fact that when you run at wfo and theres no pop/chug.
Under wfo you are using the main,tube and needle to some extent.
Sounds like an undersized pilot,or its slightly restricted/not fully since it Will idle.
Old Apr 20, 2009 | 05:09 PM
Gpsjr10's Avatar
Gpsjr10
My02 Hugger and my Nightster which is fuel injected "coughs" once in a while when it isn't at full operating temp. nothing to worry about. But a carb cleaning / inspection may be in order for you. I would try a couple tanks with Seafoam first and see if that helps.
Big Pap
Exhaust System Topics
Dec 1, 2012 10:49 PM
scotitude
Oct 30, 2010 11:10 PM
brian falcone
Mar 24, 2008 05:58 PM
bryon857
Ironhead
Feb 21, 2008 06:56 PM
Spinder
Apr 5, 2007 02:57 PM
