Help
Old May 12, 2009 | 01:28 PM
Steel's Avatar
Steel
Cool Help
Hello folks
I have a 2001 sportster 1200 custom.I was wondering if anyone knew of a heel toe shifter that would fit it. I just started wearing leg braces and have to hook my heel over the shifter to up shift.
Thanks
Wade
Old May 12, 2009 | 01:50 PM
guitarman023's Avatar
guitarman023
do you know how to weld? it wouldn't be hard to make. If not, I would say ebay would be a good bet. You can probably find one with the right splines for your shifter, and a set of floorboards.
Old May 12, 2009 | 02:05 PM
Bong's Avatar
Bong
+1 maybe ebay
Old May 12, 2009 | 03:53 PM
stng_96's Avatar
stng_96
Never know, one from a bt might fit?
Old May 13, 2009 | 02:13 PM
ou8123's Avatar
ou8123
Stage III
Hi Steel. I have drop foot. The only control I have is to push down with the front part of my foot. I mounted an old shifter on top pointing to the back so I can push down to up or down shift.Drill a 1/4 " hole all the way through both shifters and a long nut & bolt to hold them together. Drill a 1/8" hole through top shifter and part way into the bottom and pound split pin in to hold them in line. Works for me
Good luck. Bernie
fhartell14
Aug 26, 2018 07:48 AM
EvanC
Feb 8, 2015 01:49 PM
NCTRLR
Sep 4, 2013 07:26 AM
kelly hooper
Apr 9, 2008 10:08 PM
kelly hooper
Apr 9, 2008 08:46 PM
