Probably a dumb question...
Old May 14, 2009 | 10:53 PM
guitarman023's Avatar
guitarman023
Default Probably a dumb question...
Ok, '87 sporty, My turn signals worked fine until recently, and now all of a sudden they flash very very fast. All the bulbs work, would a new flasher solve this? I'm still up in the air whether it's the flasher, or a bad ground somewhere. Hoping someone has had a similar issue.
Old May 15, 2009 | 08:11 AM
bmxatv's Avatar
bmxatv
did you check the fluid in your signals, prolly need to go with a higher viscosity fluid. make sure you bleed them first. :P sorry couldn't resist.
could be a ground. did you put the contact grease (or whatever it's called) on before installing the bulbs?
Old May 15, 2009 | 09:14 AM
PHAT A$$'s Avatar
PHAT A$$
I gotta ask what's the story on the turn signal fluid? Clearly there's no fluid in there but, I've seen it mentioned in a few posts.
Jason
Old May 15, 2009 | 09:17 AM
guitarman023
lol, blinker fluid is an old joke running around parts stores for quite awhile. Just naming off things that don't exist. Muffler bearings, vw water pumps, summer/winter air, stuff like that.
Oh and yeah, the bulbs have grease on them.
Old May 15, 2009 | 09:43 AM
expolice's Avatar
expolice
Add higher viscosity blinker fluid?? I always thought the higher viscosity fluid would cause a back pressure problem and cause my brake lights to come on!!
Old May 15, 2009 | 09:52 AM
killer scott's Avatar
killer scott
That is just the kind of missinformation we try to avoid around here!
Did you check all the fuses? Just throwin ideas out there.
Old May 15, 2009 | 11:20 AM
guitarman023
no fuses, just circuit breakers, and they seem fine. the blinkers work, just flash very fast all of a sudden. It's not a huge deal, I kind of like them flashing fast, but I'm pretty sure if it's the signal relay, it's going to go bad on a road trip somewhere.
WEATHERED59
Jul 27, 2017 01:34 PM
Retirementtoy
EVO
21
Nov 18, 2014 06:22 AM
Needle750
May 1, 2013 09:32 PM
Nickm099
Apr 3, 2013 09:31 PM
PCKLST
Electrical/Lighting/Alarm
Aug 8, 2012 03:03 PM
