Stage II question
Old May 15, 2006 | 07:44 PM
bensonjv's Avatar
bensonjv
Default Stage II question
Working up the parts list for Stage II. Don't see a coil upgrade for 04-06 models. Is there nothing out there yet or is it just not necessary for 04-06?
Old May 15, 2006 | 09:11 PM
XL OCD's Avatar
XL OCD
Default RE: Stage II question
Can you send me to a link for what's all involved w/ Stage II?
Old May 15, 2006 | 09:27 PM
bensonjv's Avatar
bensonjv
There are a few variations (attached a couple links for ***-bleeding detail) of stages but the general consensus is this:
Stage 1: free flowing exhaust, high flow air cleaner, rejetted carb
Stage 2: Upgraded cams
Stage 3: Hi-compression heads and/or pistons
Links for fun reading:
American V-Tech
Sportster.org
I plan on changing cams, ignition module, and plug wires first. Supposedly the plug wires are uber cool, bigger than stock, etc. I'm changing them because I want orange ones that say "Screaming Eagle" on them. After that is done I'm looking at Hi-compression heads and pistons. So I guess that'll take me through Stage 3.
With earlier models you could/would change the coil when you did the ignition module. However, can't find one for 04-06 Sporty's yet, hence my original question.
Hope that helps.
Old May 15, 2006 | 10:14 PM
XL OCD's Avatar
XL OCD
That's a lot of good info. The second link stopped the ***-bleading that I got on the first. Does anyone know if there's any significant HP difference from the 03 motors to the rubber mounters?
DanHappy
Jan 11, 2015 12:17 PM
2010Deluxeguy
Dec 16, 2011 08:02 PM
sgtt45
May 17, 2010 07:40 AM
thedonthere
Jun 10, 2009 12:47 PM
k23rd
May 18, 2005 11:41 AM
