low compression
Old Jun 23, 2009 | 11:52 AM
ncjake3's Avatar
ncjake3
Stage II
Default low compression
I have 1978 sporty, i ran a compression check and front was 120, rear was 50. what is the problem?
Old Jun 23, 2009 | 11:57 AM
iceman336's Avatar
iceman336
could be burnt valves, broken rings, scored liner, hole in the piston, bad gaskets... won't know till you take it apart.
Old Jun 23, 2009 | 12:01 PM
ncjake3's Avatar
ncjake3
Stage II
still run good , but you can hear a vaccum leak when idling low
Old Jun 23, 2009 | 12:41 PM
guitarman023's Avatar
guitarman023
it runs good with 50psi in the rear piston?! wow that's surprising, i'm surprised it runs at all!
Old Jun 23, 2009 | 01:35 PM
FastHoss's Avatar
FastHoss
Harleys are alot tougher than most of the guys riding them
Old Jun 23, 2009 | 02:38 PM
fox4's Avatar
fox4
Are you burning oil?
Old Jun 23, 2009 | 03:21 PM
Certainteed's Avatar
Certainteed
does it stay at 50, bleed off slowly, or drop off instantly?
Old Jun 23, 2009 | 03:59 PM
Bentwrench's Avatar
Bentwrench
Default Low Compression
Be sure to run the compression test more than once to confirm the results.
If you get the same thing, then try adding a tablespoon of motor oil to the cylinder and test it again. If the compression goes way up, like doubles, then the problem is the rings or cylinder. If the compression doesn't change, then the problem can be a valve or leaking head gasket or a cracked head. (If it were a hole in the piston, you'd have a great deal of smoke.)
The easiest way to locate the compression leak is to use low pressure air in the cylinder with the piston at TDC on the compression stroke. By low pressure, I mean 30-40 psi. If it is a leaking intake valve, you'll hear the leak at the carburetor. If it is a leaking exhaust valve, you'll hear it at the exhaust pipe. If it is a leaking cylinder head gasket, you'll hear it at the joint between the head and the cylinder.
Good luck.
Old Jun 23, 2009 | 05:37 PM
diablo666's Avatar
diablo666
If it bleeds off the compression gauge is leaking.They have a valve in the end of the hose to keep the pressure in.The valve needs to be removed to air check a cylinder by the way.
Montamayor
Aug 5, 2017 06:25 PM
dragonx
EVO
23
Mar 14, 2012 08:08 AM
harley7316
EVO
Jul 6, 2011 04:13 PM
bdavis
Ironhead
Oct 2, 2006 04:02 PM
Haji4
May 20, 2006 11:25 PM
