Choke/warm up
Old Aug 6, 2009 | 04:29 PM
krazykat's Avatar
krazykat
6th Gear
This is what I do to start my bike...I got it from a source on the web for tuning the carb. First start it with the enricher FULL out...let it idle for 30 secounds, then push it in half way and then adjust the throttle set screw so it's running at a fast idle...1200 or so...for two minutes...this is on a cold motor. When the rear cylinder rocker box is warm to the touch then it's good to go. I then push it in to the 1/4 position and go for a few miles, till the rear rocker box cover is toasty. That's when I will push the enricher all the way in. Now that's an optimal condition. If it's really cold out....between 60 and 25 degrees....then the warm up times are longer and the time I leave the enricher out to 1/4 are longer. But once the motor gets up to operating temps....well then it's no holds barred! Just takes longer in the colder weather. I get so much **** from "shovel-head" guys and other non-HD owners about how long I let my bike warm up and my use of the "enricher", but I just did the plug change on my bike and I don't see any fouling of the plugs what-so-ever. Very clean and burning just swell thank you. Oh, yeah...it's always good to let a motor that has iron and aluminum parts warm up to operating temps....well , it's only important if ya want to keep it for a spell. That is my humble opinion....
Old Aug 6, 2009 | 05:06 PM
jag1886's Avatar
jag1886
Let the bike run for 30 seconds then push the choke back in 1/3 and go, if you are jetted right the choke can be push all the way in, after 2-3 miles.
Old Aug 13, 2009 | 05:32 AM
3737pisces's Avatar
3737pisces
Default Choke On at start up
I was told when Mikuni 42 Carby,Cam work,V&H pipes,Ignition Module put on to Always pull Choke out when first start bike & let choke slide in once warm. Other Night Very Cold weather & put choke out,waited to warm bike up then off I went. Next bike coughing..spluttering..on road for say 1klm. Is it due to the Cold weather? or the fact i forgot to turn the Fuel Off when I first arrived A/noon at my destination..Normally I turn Fuel Off but forgot to do so. Can anyone suggest why bike spluttered,coughed (It was Freezing weather at Night).Never does the Bike do this!
Old Nov 16, 2016 | 10:25 AM
drifterfcrc's Avatar
drifterfcrc
2nd Gear
Default It's an enrichener **** and not a choke
HD says in their owner's manual to start with the enrichener pulled out for 30 seconds and then ride it for a couple miles and then push in half-way for another couple miles and then all the way in after that for temps colder then 60 degrees. Warmer weather then do the same but for shorter distances. Warm or hot engines the enrichener is not needed and open the throttle a little to start the bike.
Old Nov 16, 2016 | 11:21 AM
John Harper's Avatar
John Harper
Originally Posted by jgcable
my stock 1989 883 takes a good 15 minutes to warm up in the summer. For the first 15 minutes she spits and coughs through the carb something aweful. Then... 15 minutes later its like a switch turns on and she smooths out and runs perfect. This happens EVERY time I start the motor up when it is cold. This is in high 80 degree weather. I have tried everything and I can't get the bike to run good when the motor is cold.
Change out all your intake seals, rebuild the carb, especially with a new accelerator pump diaphragm. Make sure your pilot jet is a 45 and a 175 mainjet. Be sure to clear out all passages, especially the pilot jet/mixture screw passage. Mine was all clogged up with 25 years of fuel deposits.
My bike had the same symptoms, they are all gone now.
John
Old Nov 17, 2016 | 04:59 AM
atrox88's Avatar
atrox88
In cold weather I warm it up for about 2-3 minutes. I take off with the choke fully engaged and ease it in as I ride. Warm weather I only let it warm up for a minute, ease it in a bit then take off. I am always easy on the bike until I have ridden it for a few minutes or more, depending on the temp.
Old Mar 20, 2017 | 07:23 PM
John843's Avatar
John843
Stage I
I have a 98 sportster 1200 custom. I cleaned my carb for the first time and after putting her back together and starting her it sounds like choke is on even when it's not. I usually always have to use choke to warm her up but now she'll start up just fine even in 50 degree weather with no choke .. I took off my carb again to check it and everything seems fine does anybody know what might be going on??
essentialcycle
Carburetor Related
Sep 18, 2014 10:19 AM
Whitey1
EVO
14
Mar 5, 2013 07:07 PM
JerryDinMD
Jun 20, 2012 01:00 AM
CoachMcGuirk
Jun 9, 2011 01:52 PM
rhirsch1
Nov 30, 2010 04:40 PM
