re-jet/re-map
Old Jul 18, 2009 | 11:25 AM
UKHD's Avatar
UKHD
6th Gear
Default re-jet/re-map
Is there a way of knowing if a bike that is advertised as having Screaming Eagle exhausts has had a re-jet/re-map?
Would the bike run badly if it hadn't ?
Old Jul 18, 2009 | 11:47 AM
eazyrider's Avatar
eazyrider
Okay we need a year to be able to help. Usually when you just do pipes then nothing else is needed.
Old Jul 18, 2009 | 12:29 PM
UKHD's Avatar
UKHD
6th Gear
I've been looking at 2004/05 883R's I read they can run lean if not re-jetted or re-mapped whichever is required.
As I will be buying second hand I wondered if there was a way of knowing the work has been done.
Old Jul 20, 2009 | 10:53 AM
WVHogRider's Avatar
WVHogRider
If you're looking for a pre-EFI bike, which would be '06 and older, you will need a re-jet. 2007 and up are EFI that will need a re-map. To see if the carb has been re-jetted, you can look to see if the plug on the carb has been drilled out.....Check the DIY Sticky at the top of the maini sporty page and find the Re-Jetting thread and you'll see what I'm talking about for the plug.
Curly61
Jul 15, 2018 04:31 PM
jfuller9
Jul 28, 2013 09:26 AM
Beauregard
Feb 1, 2013 08:28 AM
Mojo1977
Sep 27, 2012 03:10 PM
crazy_walt
Jun 11, 2011 12:27 AM
