Sportster Fork Lock
Old Jul 23, 2009 | 01:08 PM
justryd's Avatar
justryd
Stage III
Default Sportster Fork Lock
I just bought a 2005 883C for my wife. Only has 5K miles. In great condition. I just can't get the fork lock to engage. The cylinder will not rotate. Any help is welcome. Thanks.
Old Jul 23, 2009 | 01:56 PM
cHarley's Avatar
cHarley
Are you turning the forks all the way to the left before trying to operate the lock?
Old Jul 23, 2009 | 02:01 PM
justryd's Avatar
justryd
Stage III
Yes. Thanks. Even though my 6th bike ... still good question.
Old Jul 23, 2009 | 02:36 PM
cHarley's Avatar
cHarley
Well, I'd say you've got 1 of 3 things going on. Either the lock cylinder is broken, the locking pin isn't lining up with the hole in the neck, or the previous owner replaced the cylinder and the ignition key wasn't matched to the new fork lock cylinder.
Sorry for the apparent dumb first question, but I learned a long time ago to always ask a computer customer that called and said his system wouldn't turn on, whether or not it was plugged in.
Old Jul 23, 2009 | 08:34 PM
foxtrot's Avatar
foxtrot
I had a problem at first on my 09 1200C now I turn the forks as I turn the key when the slot inside lines up the key will rotate.
Old Jul 24, 2009 | 06:40 AM
justryd's Avatar
justryd
Stage III
Thanks. I'll try each of these suggestions.
Old Jul 24, 2009 | 07:55 AM
HarleyScuba's Avatar
HarleyScuba
Originally Posted by cHarley
... or the previous owner replaced the cylinder and the ignition key wasn't matched to the new fork lock cylinder.
Or, they replaced the ignition switch. You can verify the key code on the key. Pull the black plastic cover off the top of the key. There will be a 3 or 4 letter/number code stamped on the key. Call your local dealer and give them your VIN. They'll be able to check your key code on the dealerships HD.net.
Old Jul 24, 2009 | 08:00 AM
JayStronghawk's Avatar
JayStronghawk
Personally never worried about a Fork lock on a sportster.. But good advice has been given..
jalexmontes
Mar 13, 2019 01:24 PM
rebel7
Sep 25, 2016 04:27 PM
chorndawg
May 10, 2012 10:08 AM
Azrael
May 9, 2007 09:59 PM
biker77
Apr 25, 2007 08:59 PM
