Check your DTC's. The CPS will typically throw codes P0373 or P0374
And yes, I've been through 3 sensors.
i read part of that sticky..... i don't have a speedo soooo can i take that bike to someone so they can plug it into something and tell me what is wrong???
The crank position sensor tells the ECM where the crank is so the ECM can fire the plugs at the right time, if it fails the ECM thinks the crank is not rotating so no spark, it is located at the front of the motor beside the oil filter.
I agree with cHarley about the trouble codes, check them first, if there is more than one stored clear them and check them again after it does it again.
ok i know exactly what yr talkin about....been leakin a little ever since i got the bike .....maybe ill push on it or something
still not sure how to read the codes without a speedo??
I think the CPS is pretty cheap and if yours leaks anyway I'd change that and see what happens.
cHarley, did you have similar symptoms when yours went?
Yep, but the symptoms were varied each time (3 times). They aren't cheap ~$50.00 a pop and non returnable.
These sensors have a history of failing and it seems to be related to heat. I have installed a C clip on the mounting screw under the sensor to give the sensor about a .010" standoff and it seems to have improved the situation. I'm thinking these sensors really need some form of a heat sink, as these issues keep cropping up in the summer months. I'm seeing this problem mentioned on other HD forums as well.
Heat does have alot to do with them. Heat makes the plastic brittle and causes cracks, thus causing it to lose contact, but shrinks back up when cooled down making contact.
I have never seen the pickup housing crack, but they do seem to fail (throw dtc codes) when the motor gets really warm in the summer months. I've got 3 sensors on the work bench that look and test fine, but they all throw DTC codes P0373 once the motor gets up to 200+* (oil temp) and you push for over 90 MPH in 4th or 5th gear.
