stumped, need to figure this problem out now....the sagga continues
figured ahhh maybe a fluke thing....tore her down (chopped cam cover and pulled the primary cover) put it all back together and i went for a ride today and she did it 2 times that ride (about 45 miles) then 1 during another ride (about 30 miles) all the times the bike was hot (got a turkey temp thing today, temps are reading at 190 F) i have an oil cooler (jagg) but i'm not sure what the issue is???
bike starts and seems to run just fine. and she doesn't seem to chug then cut out, just shuts right off for some reason?? fire her up and i'm good to go riddin some more.
i have not checked the plugs, gonna go out and do that now, i haven't done anything to the carb. same gas, i did instal a new inline fuel filter but i have always had one, this one is just new,
i have noticed randomly that after its been runnin sometimes i will hit the starter button and there will be a lag, but that has happend in the past (i think i read on here somethin about when the bike is hot it will just do that sometimes).
anyone have any clues????
my first thought is to pull the carb and clean the jets but with a new fuel filter that doesn't seem to make sense.....
ideas....suggestions????
Have you checked the infamous battery connections, also check the fuse box for corosion, other than that maybe a bad coil or crank position sensor?
my coil is and has been instaled upside down and i was having issues when washing it until i put some plug greese on it...now it works fine...or it has been till now
i don't think its the oil pump because my oil temp is stayin pritty consistantly at 190 F ...wouldn't it be hotter if it wasn't pumpin right???
how do i check for oil pressure??
i have heard a bit about these crank position sensor, can you explain what and where it is and what it does? ( if its to much a PITA to do i deffinetly understand)
at this point i'm startin to think coil crank position sensor....
And yes, I've been through 3 sensors.
