HELP!! Enrichner Knob stuck..Bike won't Start
Old Aug 16, 2009 | 02:47 PM
congo_usmc's Avatar
congo_usmc
Default HELP!! Enrichner **** stuck..Bike won't Start
Alright Yesterday coming home from work my enrichner **** WAS stuck in. After a little struggle it came out. After the bike heated up the **** would not go back in. It was liek a vaccuum was holding it out, whenever I pushed it in it would push back out. after about halfway through my ride home(15 Miles) I was able to get it halfway in. This morning I go to mess with the bike and the **** moved in and out real loose like it wasnt connected to anything. the bike ran for about a minute then died. It cranks but won't turnover now. whats the deal? does the enrichner **** connect to a cable? or is it hydraulic or run on a vaccuum? I'm hoping the cable just tore or something and I can just replace it. Thanks ahead of time for any help.
UPDATE BELOW
Old Aug 16, 2009 | 03:11 PM
RATROD HOG's Avatar
RATROD HOG
ONLY HAND tighten the FRONT **** at bracket
NOT the back one
Old Aug 16, 2009 | 03:13 PM
congo_usmc's Avatar
congo_usmc
NOT the back one
so your saying i need to replace the cable?
Old Aug 16, 2009 | 03:17 PM
xFreebirdx's Avatar
xFreebirdx
The plastic nut on the front where you pull it is too tight.
Old Aug 16, 2009 | 03:28 PM
congo_usmc's Avatar
congo_usmc
now its real loose though like its not connected to anything. I have never had this problem before and I didnt adjust the screw so theres no reason why it shoulde be to tight.
Old Aug 16, 2009 | 03:32 PM
RATROD HOG's Avatar
RATROD HOG
here is a picture of ****
tighten or loosen it
Attached Thumbnails HELP!! Enrichner Knob stuck..Bike won't Start-8-16-09-070.jpg
Old Aug 16, 2009 | 08:19 PM
Gpsjr10's Avatar
Gpsjr10
It is connected to a cable and it is possible you have a problem with it, but check the friction **** like was stated before, just be sure not to strip the threads, it is plastic.
Old Aug 17, 2009 | 12:31 PM
congo_usmc's Avatar
congo_usmc
UPDATE: So I checked the friction **** everything was good there I pulled off the filter and got to the carb. I am assuming that the choke connects to this door because it has fallen and I can move it freely with my finger. I dont remember this door (for lack of a better word) being down in previous times I have taken off the filter. can someone confirm this? I' m attaching a few pictures of it down and me pushing it up. I didnt get a chance to follow the cable today Im gonna have to take the tank off. Im hoping that I can just take out the bad cable and replace it or just reattach it if it happened to disconnect. BTW there were no diagnostic codes.
Attached Thumbnails HELP!! Enrichner Knob stuck..Bike won't Start-100_0856.jpg   HELP!! Enrichner Knob stuck..Bike won't Start-100_0857.jpg   HELP!! Enrichner Knob stuck..Bike won't Start-100_0858.jpg
Old Aug 17, 2009 | 03:27 PM
WVHogRider's Avatar
WVHogRider
Yah, I'm uh thinking you broke the farrel off the end of the cable to the back of the carb, and it's just moving freely now. The new cable is not that expensive.
Old Aug 17, 2009 | 04:13 PM
RATROD HOG's Avatar
RATROD HOG
that door as you call it (vacuum piston),works off of vacuum.
should slide up and down,it is spring loaded
