Pull back handlebars?
Old Sep 7, 2009 | 12:56 PM
Harleyduo's Avatar
Harleyduo
Default Pull back handlebars?
OK, here's our problem. We have a female rider that is trying to get her best fit on a Sportster. Since it's a 1200Low, we're all set on the leg reach situation, but now we need to address how to get the handlebars back further to her so she doesn't have to lean forward while riding. To make matters more complicated, we'd like to try to achieve this without having to replace all the cables. There seems to be a bit of 'play' with the standard cables, so we're hoping somebody else has already faced this situation and can recommend a 'solution' that will do exactly what we need to do. One parts guy suggested a pair of curved risers, but since the speedometer fastens to the riser area we fear that would also tip up the speedo to almost vertical. Another solution offered was mini-ape hangers and tilt them down so they come backwards, but it seems that would turn the part you hold onto also almost vertical and would not be acceptable..
Has anybody faced this and found a workable solution? Any help would be greatly appreciated.
Thanks,
Old Sep 7, 2009 | 02:00 PM
RATROD HOG's Avatar
RATROD HOG
did you try rolling the bars back alittle?
Ride Safe
Old Sep 7, 2009 | 02:54 PM
Harleyduo's Avatar
Harleyduo
Default Tried it...still too long of a reach
IF by rolling back the bars, you mean tilting them so that the rise of the handlebars becomes angled so it helps get them back closer to the driver, then we did that, and they are still just an inch or two or three too far forward. I'm sure somebody has put on a set of bars to solve this problem, but I don't want to be the 'guinea pig' to experiment if somebody has already been down that road.
Old Sep 7, 2009 | 05:16 PM
capttawes's Avatar
capttawes
Check out the harley pullback bars which come back about 2" more (may still need some new cables). Also check out www.sideroadcycles.com which handles Flanders bars (pricey but good selection). Flanders make a a few styles with decent pullback and I believe the flat track bars come back pretty far without being too tall or wide.
Old Sep 7, 2009 | 06:26 PM
Gpsjr10's Avatar
Gpsjr10
You can also replace the risers, they make some that will bring the bars back an inch or so.
Old Sep 8, 2009 | 07:19 AM
novabeast69's Avatar
novabeast69
We are running into a similar problem on a nightster for my wife. Seat height ok but bars don't allow for the riding position she's looking for. The 2010 883L bars fit her and I may look into these to see if they can be used on nightster. If they can, I would look into powder coating them black.
Old Sep 8, 2009 | 09:13 AM
vet767's Avatar
vet767
If it helps, I put the HD buckhorn bars on mine. The kit comes with the cables and lines you need. There is plenty of slack in the wires, you just need to remove the tank to pull the slack. They can be tilted back and solved my reach problem.
Old Sep 8, 2009 | 12:44 PM
tiger_rider's Avatar
tiger_rider
A lot depends on the size of the rider. I had to go through about 6 months of adjustments to get our 1200L set up for my wife. In the end we went with mini-apes and pullback risers, and we needed new cables. The mini-apes by themselves were a big improvement but the pullbacks sealed the deal. They did cause the speedo to be vertical, but, because my wife is short there wasn't a problem, she could still see it ok. See attached picture.
Bushy
Jan 27, 2018 09:59 AM
CobraEd
Nov 6, 2012 05:05 AM
cozziem137
Sep 10, 2010 07:42 AM
PktChg
Aug 12, 2010 10:04 PM
abadfatboy03
General Topics/Tech Tips
Apr 20, 2010 06:26 PM
