dyno run
Old Jun 17, 2006 | 04:46 PM
wideopen's Avatar
wideopen
Default dyno run
Well I rejetted my sporty yesterday and today I took it to the local HD dealer to get the to fine tune on the dyno, they did 2 pulls with it and asked me what I was complaining about. My air/fule ratio was perfectly flat and they couldnt do anything, still charged me $35 but oh well still fell good about it. If I ever get a scaner I will post it up.
2000 1200c
V&H staight shots
screaming eagle airfilter kit
180 main
48 pilot
2.5 turns out
1988 1200 sporty needle with 1 shim
64.47 HP
68.79 Tourqe
Old Jun 17, 2006 | 05:09 PM
AZFlyingDiver's Avatar
AZFlyingDiver
Default RE: dyno run
Any comment from them about the pipes holding your HP/torque numbers down a little? I'd think you should get closer to 70 HP and TQ with your setup if you had a 2-1 pipe or even SE's or CS's. Pipes (especially drags, Straight Shots, etc.) can actually hinder things a bit (although they sound great). With drags, etc. there's less reversion and thus less efficient cylinder fill (and less power than possible)...Just a thought...
Old Jun 17, 2006 | 05:15 PM
wideopen's Avatar
wideopen
Actuuly the only thing they said was to get an ignition module because my bike was still making hp and torque but the revlimiter kicks in a 5200rpm actully the hp curve was still pretty steep at that point
Old Jun 17, 2006 | 05:17 PM
AZFlyingDiver
ORIGINAL: wideopen
True - it'll be strong up to about 6800RPM or a little more...
Old Jun 17, 2006 | 05:32 PM
wideopen's Avatar
wideopen
here is the dyno sheet took a pic of it with the camera
Old Jun 17, 2006 | 07:39 PM
OldFenderGuy's Avatar
OldFenderGuy
We checked the stock 'rev-limited' on my '05 1200C, and it was set right at 6,000 RPM.
But even with the "E" cams that were installed, the horsepower peaks right at 6,000 RPM, stays there for a few hundred RPM, and then starts to drop.
Because of that I decided not to go with an aftermarket ignition module. If it were set up strictly for drag racing I might want to shift in the 6,400 RPM range so the bike wouldn't drop out of the peak horsepower/torque range between shifts, but the 1200C is for street use.
I don't take the bike up to 6,000 RPM that often, but even so, there isn't any point in running at a higher RPM as I wouldn't be gaining any additional power.
JimGnitecki
Engine Mechanical Topics
172
Feb 5, 2015 02:31 PM
txphatboy
Jun 2, 2012 05:41 PM
csbreeze
Apr 26, 2011 09:19 PM
mhud
Mar 4, 2009 05:07 PM
SDMF
Jul 3, 2006 09:27 PM
