Ethanol gas
Old Sep 23, 2009 | 06:00 PM
dkin01's Avatar
dkin01
Default Ethanol gas
Being a newcomer, is there any thoughts good or bad on the ethanol gas in a sportster, and what grade of gas would you recomend?
thanks
Dave
Old Sep 23, 2009 | 06:04 PM
xxxflhrci's Avatar
xxxflhrci
Been running ethanol in everything I own for years now and had no problems.
Why not check your owner's manual for the octane rating? The recommended octane sometimes varies according to the model/year you have.
Old Sep 23, 2009 | 06:23 PM
OldFenderGuy's Avatar
OldFenderGuy
Guess I am lucky, as we can still get 'straight' 92 octane fuel in my area.
Anyway, I pulled out my Softail Owners Manual, and this is what HD says about gasoline blends, and I would imagine the wording in the Sportster Manual is the same;
Gasoline Blends;
Your motorcycle was designed to get best performance and efficiency using unleaded gasoline. Most gasoline sold in the United States is blended with alcohol and/or either, to create oxygenated blends. The type and amount of alcohol or either added to the fuel is important.
CAUTION; Do not use gaoline that contains methanol. Doing so may result in fuel system component failure, engine damage and/or equipment malfunction.
* Gasoline containing METHYL TERTIARY BUTYL ETHER (MTBE): Gasoline/MTBE blends are a mixture of gasoline and as much as 15% MTBE. Gasoline/MTBE blends can be used in your motorcycle.
* ETHANOL is a mixture of 10% ethanol (Grain alcohol) and 90% unleaded gasoline. Gasoline/ethanol blends can be used in your motorcycle if the ethanol content does not exceed 10%.
* REFORMULATED OR OXYGENATED GASOLINES (RFG): Reformulated gasoline is a term used to describe gasoline blends that are specifically designed to burn cleaner than other types of gasoline, leaving fewer tailpipe emissons. they are also formulated to evaporate less when you are filling your tank. Reformulated gasolineuse additives to oxygenate the gas. Your motorcycle will run normally using this type of gas and Harley Davidson recommends you use it when possible, as an aid to cleaner air in our environment.
You may find that some gasoline blends adversely affect the starting, driveability or fuel efficiency of your motorcycle. If you experience one or more of these problems, its recommended you operate your motorcycle on straight unleaded gasoline.
Old Sep 23, 2009 | 06:40 PM
dkin01's Avatar
dkin01
thanks guys, I bought it used no owners manual.
Dave
Old Sep 23, 2009 | 06:47 PM
cHarley's Avatar
cHarley
What year bike and what engine size (883 or 1200)?
Old Sep 23, 2009 | 08:40 PM
diablo666's Avatar
diablo666
Don't be trying the E85 fuel it will eat rubber components in a fuel system not designed for it.Your bike would need to be flex fuel to use it.It gets a little more technical after that so I will leave it at that.
Old Sep 24, 2009 | 03:09 AM
dkin01's Avatar
dkin01
it's a 2001 883.
thanks
dave
Old Sep 24, 2009 | 03:14 AM
JayStronghawk's Avatar
JayStronghawk
Have had no problems with my 2001 with 10% Ethanol Just go with the Higher Octane 93
Old Sep 24, 2009 | 06:37 AM
WVHogRider's Avatar
WVHogRider
Originally Posted by dkin01
it's a 2001 883.
thanks
dave
An '01 883 will call for 87 octane, , but you can put in higher octanes if you want.
Old Sep 24, 2009 | 08:57 AM
fox4's Avatar
fox4
If you want to run e85 it takes ~20% more fuel to get the same spark as gasoline. You could start out by getting some sort of tuner and adding 10-20% across all the fuel trims. If you run out of injector before that (which you probably will), you will need bigger injectors and probably a bigger fuel pump as well. DOT lines are fine, they aren't going to melt instantly by putting e85 in them. But they will wear a little faster (5 years instead of 10)
