Loose stuff
Old Sep 27, 2009 | 07:19 PM
harleyspider73's Avatar
harleyspider73
Default Loose stuff
Ok so I did an oil change today at 8300 miles.....it was the 3rd one. anyways, I was wiping away some oil and found this Steel braided line loose on one end, there is some linkage there too.
Anyways to get to this thing and tighten, you have to take apart lots of things. Including the brake system so you can get behind the hose.screws are very tight. This is just a bracket right?
http://s383.photobucket.com/albums/o...t=DSCN1293.jpg
Old Sep 27, 2009 | 09:10 PM
gilmour68's Avatar
gilmour68
Looks like a ground cable.
Old Sep 27, 2009 | 09:15 PM
old skool1983's Avatar
old skool1983
yupp, its a ground cable hooked to your rubber mount. you can deffinetly leave it alone but if you start having wierd electrical problems....that should be yr first suspect
Old Sep 28, 2009 | 06:42 AM
xFreebirdx's Avatar
xFreebirdx
Get under there with some needle nose vise grips.
Old Sep 28, 2009 | 10:58 PM
harleyspider73
Default yes, needle nose vise grips
Thats what I did
Old Oct 4, 2009 | 01:03 AM
harleyspider73
its not a ground wire, its not wired to anything.
Old Oct 4, 2009 | 02:04 AM
dm76's Avatar
dm76
it could still be ground...just not connected directly to any wiring. Could be a link to two different engine components that continues the ground circuit...if that makes sense.
Old Oct 4, 2009 | 07:07 AM
RATROD HOG's Avatar
RATROD HOG
no it's not a ground strap!!
it's a wire lock for the rear swing arm when it flies off damn
Old Oct 4, 2009 | 12:47 PM
mjmangus's Avatar
mjmangus
It's a ground. Some components are not grounded due to the rubber mount so this is installed to make it the same, electrically, as the frame. Just curious, what would you expect it to be wired to?
Old Nov 18, 2009 | 11:35 PM
harleyspider73
Default Its not a ground, its a wire lock strap.
and the damn thing keeps coming undone. Can I put some locktight on it? I tighten it up every week and it keeps wiggling loose, but it can't totally fall out!
