Hey guys I'm tryin to install the 2 IED O2 wires that came with the bike. I believed I installed them correctly but theres still popping in decel. I was wondering if I had to completely remove the original wires and replace them with these or do I just add these between the original area where they connected
Now I drawed a picture to help explain cause I couldnt find a picture of the install, please hang in there with me
I didn't remove anything. I just plugged the IED inbetween the two original wires. The bike is Stock accept Rush Pipes. Thats why I put this on instead of a PC or something like that until I more highly modify the powerside
You wasted your $$ on the IED's! Now then, spend more $ on a Intake and more $ on a Stage 1 Down Load, which is still a waste as that program is also lean. When you have the extra $$, buy the TTS and have it tuned right! BTW, you installed them correctly, they run between the harness.
Well I didnt really spend any money on them, they came in a box when I bought the bike from a guy. He had a bunch of accesories for it but never installed any of them. So I thought that it couldn't hurt it to put it on until I bought more stuff for it
It won't hurt it, but also doubt you will see or feel any difference! The IED will throw a code, but it won't hurt or effect anything. It just irritates me that so many people want to throw on a band aid fix for a problem that needs serious attention. I understand the $$ thing, but if someone is going to do something, they should just do it right the first time and be done with it. In the long run, it's $$ saved..
