wheel bearings...
Old Feb 13, 2010 | 09:54 AM
mballard's Avatar
mballard
Default wheel bearings...
wow,, so many forums ?,,,,not quite sure where to post...?
just looking for advise/recommendations on jacking (balancing), removing front and rear wheels and checking the whel bearings.
old '89 has 30k miles, but has been sitting for a good ling time. just want to make sure wheels, tires, brakes and bearings are in good order (first)..
would appreciate the do's and don't...thanks, marion..
Old Feb 13, 2010 | 01:12 PM
Stefan's Avatar
Stefan
To my understanding the pre 2000 wheel bearings are not sealed & require greasing every 10,000 miles, similar to the head bearings on current moddels. If your axle has ever been hit with a hammer (stealership's favorite method of removing axles) then you will not be able to check the wheel bearing runnout by the mag base indicator placed on the brake disc. I have only worked on the 2000 & newer sealed wheel bearings & neck bearings. Easy stuff, lots of grease.
ps RTFM
Old Feb 13, 2010 | 02:34 PM
jag1886's Avatar
jag1886
You need a jack and a manual for your bike there are very specific procedures for packing bearings on the older bikes..
Old Feb 13, 2010 | 04:15 PM
olddude48's Avatar
olddude48
I use blocking under the frame. Slide the biggest block possible under the frame with your bike standing up straight 6x6 or 8x8. I then tip it to one side and slide a 1x4 or 2x4 under one side of the frame,then do the other side. It may not be balanced front to rear. Pull one wheel at a time and do the bearings.
Old Feb 14, 2010 | 04:58 AM
mballard's Avatar
mballard
good ideas/suggestions,,want to ride,, but want to ride safe....thanks,,,mb
mike_oh
Feb 1, 2016 07:58 PM
hardheaded
May 15, 2014 03:24 PM
hardheaded
Jun 21, 2013 08:50 AM
arnold
Nov 23, 2010 06:33 PM
nafarmboy
Wheels/Tires
Feb 15, 2009 11:09 AM
