Front Wheel
Old Feb 14, 2010 | 10:24 AM
slider44's Avatar
slider44
Default Front Wheel
I need a little help please. Will a 2007 883c 21in. 40 spoke front wheel fit a 2008 883L that has a 19in. front wheel ? I want a front spoke and put a little lift on my bike..Thanks
Old Feb 14, 2010 | 10:26 AM
schumacher's Avatar
schumacher
yes, I think it will
Old Feb 14, 2010 | 12:37 PM
slider44's Avatar
slider44
Thank You!
Old Feb 14, 2010 | 12:44 PM
WRAITH's Avatar
WRAITH
Yes it will fit.
Old Feb 15, 2010 | 10:05 PM
slider44's Avatar
slider44
Thank You !
Old Feb 16, 2010 | 07:26 AM
WVHogRider's Avatar
WVHogRider
Sure it will fit, but it's not going to lift your bike any. The difference in size is unnoticable....The 19" with the larger sidewall & tread tire is almost the exact same size as the 21" with the smaller sidewalled tire.
Old Feb 16, 2010 | 02:19 PM
aeproberts's Avatar
aeproberts
It should be exactly the same size. Unless you are changing the rubber too (which might not be a good idea) then it will not lift your bike at all.
Old Feb 17, 2010 | 10:19 PM
slider44's Avatar
slider44
What if I use the forks off of a 883c with the 21in. spoke wheel????
Old Feb 17, 2010 | 10:25 PM
SportyPig's Avatar
SportyPig
Exactly! the 19 inch wheel uses a different size tire, and the overall outside diameter of the rubber is the same.
Old Feb 18, 2010 | 07:35 AM
WVHogRider's Avatar
WVHogRider
It still shouldn't give you any real difference in lift. If you want lift in the front, you'd have to get longer fork tubes, say 4", 6", or 8" overtubes. If the tubes you state above are from a "Custom" model, they may be a little longer, but I can't remember if HD used different tubes between the models or just shorter springs inside the tubes to acheive the height on the "Low". I'm not sure what you trying to accomplish though.
