Broken rear wheel belt sprocket bolts
Old Feb 21, 2010 | 02:53 PM
DENGUY's Avatar
DENGUY
Default Broken rear wheel belt sprocket bolts
Today I was riding my stock 95 1200 when I heard a pop and the back end started fishtailing. Thought I had a flat and stopped. Tire was OK. Got down and looked, found 2 of 5 sprocket bolts were sticking out and hitting the swing arm. Pulled the stock cast wheel and found 3/4" of the 3/8" bolts broke off and fused down into the threads of the wheel hub, I could barely get the 3 good ones out. Anyone have any luck getting the broken pieces out? Anybody have a stock wheel for sale?
Old Feb 21, 2010 | 03:30 PM
HOTLAP's Avatar
HOTLAP
You should be able to get them out by soaking them with penetrating fluid and using an easy out.
Old Feb 21, 2010 | 04:46 PM
bmxatv's Avatar
bmxatv
get yourself the "grabit tool". worth it's weight in gold! glad to hear you're still alive! http://www.aldencorporation.com/grabit/
Old Feb 21, 2010 | 05:08 PM
schumacher's Avatar
schumacher
so they were all loose?
Old Feb 21, 2010 | 05:20 PM
motordrum's Avatar
motordrum
You can also get a set of bolt extractors (EZ OUTS) at any hardware store. They work GREAT!!! I'm always stripping and busting bolts!!! You just drill a pilot hole in the broken bolt, hammer in the bolt extractor and wrench off. I've never tried the "grabbit", but I've heard good things.
Old Feb 22, 2010 | 06:07 AM
DENGUY's Avatar
DENGUY
Thanks for the tips. These bolts have been in place for 15 years but I am going to try and save this wheel. I would advise anyone with an older HD to change their rear sprocket bolts.
skeetb1100
Apr 29, 2019 11:18 AM
eafxstc99
EVO
Mar 7, 2015 10:00 AM
Oktane Venom
May 26, 2014 02:27 AM
Egldr05
Apr 3, 2013 11:41 AM
SpiderPig
Jun 24, 2009 08:49 PM
