Front Tire Question
Old Mar 7, 2010 | 12:50 AM
Lardog666's Avatar
Lardog666
Question Front Tire Question
situation:
front tire leaking air, rim is laced spokes.
Question:
what are the pros & cons of putting a tube in it rather than getting a new tire?
the more people chime in the better.
thanks.
Old Mar 7, 2010 | 07:03 AM
cHarley's Avatar
cHarley
If you have the stock, laced front wheel as shown in your sig pic, it should already have a tube in it. Get a new tube.
Old Mar 7, 2010 | 07:08 AM
tiger_rider's Avatar
tiger_rider
For a temporary repair you could use something like Slime to fix the leak. If you have laced spokes then you should already have an inner tube.
Old Mar 7, 2010 | 07:45 AM
SpoilSport's Avatar
SpoilSport
If tire is still good ... then replace the tube ... maybe a pin hole.
Old Mar 7, 2010 | 10:57 AM
WRAITH's Avatar
WRAITH
It's safe to reuse the tire, just replace the tube.
Old Mar 9, 2010 | 11:35 AM
WVHogRider's Avatar
WVHogRider
And don't forget to get a new rubber band to cover over the spokes and check to see if all the spokes are properly tensioned.....It could have been a loose spoke nut that worked through the rim liner and into the inner tube causing the leak.
Old Mar 9, 2010 | 12:56 PM
Grammaton's Avatar
Grammaton
Okay...
Laced wheels already have a tube in them. Replace the tube and check the rim strip. It might be worn over a spoke nipple.
brudford
Jul 24, 2018 09:47 AM
Iron lHorse
Oct 13, 2015 04:48 PM
AAAC
May 2, 2015 05:09 PM
CrossBones79
Aug 13, 2010 04:26 PM
bobbyd3
May 5, 2008 08:11 PM
