Need some quick advice
Old Mar 22, 2010 | 12:37 PM
Bigdaddy1122's Avatar
Bigdaddy1122
Default Need some quick advice
2006 Storty Custom 883 carborated added heavy breather and it was already re jetted prior to the installation due to it having a Screamin Eagle air cleaner installed by Harley prior to me getting the bike. They told me all I would need to do is add the Heavy Breather and it should be fine.
Carburetor is burping/spitting/possible backfire CHECK ENGINE light will come on and off once in awhile as well
This means its getting too much gas ? Is this just a simple carb adjustment or do you think it needs re jetting ?
I have the re jet Dyno kit in front of me and there is the following still in the container
160 jet
170 jet
180 jet
So it looks like they used the 190 jet Main
Could this just be a carb adjustment ?
Please help I'm planning on a trip for Wed !
Old Mar 22, 2010 | 12:54 PM
xFreebirdx's Avatar
xFreebirdx
if a 190 is in it. thats way to big.
cHarley's Avatar
cHarley
Need to know what exhaust you're running with the Heavy Breather before a jet recommendation can be made. Air In / Air Out, work hand in hand.
Old Mar 22, 2010 | 01:00 PM
Bigdaddy1122
There called Custom Chrome Exhaust
Old Mar 22, 2010 | 01:16 PM
cHarley's Avatar
cHarley
I'm guessing those are just "slip on" mufflers. More important than the main jet is the Pilot jet size. What's installed in the carb? A #45 should be the Max Pilot on an 883 with a Max 175 Main for a typical Stage 1 setup.
Old Mar 22, 2010 | 02:27 PM
Bigdaddy1122
I'm not sure what the Pilot is I guess I will just take it top Hop's Cycle and have them look into this ! Runs great just at start and stops it spits sometimes and I don't like th engine like coming on here and then ! Thanks for the help guys !
fred111
Apr 9, 2020 08:41 PM
Chad Hansen Jr.
Carburetor Related
Feb 17, 2019 04:18 PM
Half-Fast Deuce
Mar 19, 2013 05:00 PM
armydawg
Jul 1, 2012 09:32 PM
harleyflyer
Mar 4, 2010 08:51 PM
