She's sputtering.....
Old Mar 30, 2010 | 04:00 PM
xFreebirdx's Avatar
xFreebirdx
Originally Posted by jhowle6
any pipe that changes the air in or air out ratio requires a rejet, even slip-ons. In some cases the difference is to the intake setup is very minute but i do promise you that slip-ons are free-er flowing. The header is just a pipe that offers no back pressure. the baffleing in the mufflers is what gives this.
Pipes are not going to change the intake enough to require a rejet....At the most maybe adjust the idle and A/F ratio.
Old Mar 30, 2010 | 04:12 PM
cHarley's Avatar
cHarley
+1 Freebird - On a stock bike the A/C is what is restricting the total "in/out" air flow, much more so than the exhaust. With the A/C limiting the the amount of air drawn into the carb, the A/F ratio isn't going to change regardless of the exhaust installed.
Old Mar 30, 2010 | 04:48 PM
jag1886's Avatar
jag1886
You do have to rejet for slip ons on the older bikes, they ran so lean off the show room floor you needed to rejet even if you didn't do anything to them.
I would guess your real problem though is dirt in the carb. A 10 year old bike should have the carb pulled and cleaned properly.
Mechanic in a can is only a bandage and my help for a very short time but the real problem will continue to come back.
I'd pull the carb clean it jet it properly 45 slow jet 180 main and change the plugs, heck the plugs alone could be causing this problem.
imaguitarenthusiast
General Topics/Tech Tips
May 31, 2019 12:36 PM
Chainsaw06
Mar 16, 2019 06:55 AM
M3T4LM4N
Jul 31, 2017 12:53 AM
aconnor303
Shovelhead
Nov 17, 2014 11:12 AM
beatmasterspeech
Nov 11, 2010 12:25 PM
