nightster help
Old Apr 6, 2010 | 10:08 PM
83sporty's Avatar
83sporty
Default nightster help
its a 2008 nightster. i got it with 900miles on it. it now has 5900miles. i put 5k and the bike has ran great.. when i got it it had V&H straight shots. the last fews day it started backfiring. so i put new plugs in and the same.. the stealer ship says i need a power commander and 3 hours for tuning for 700.. i just don't understand why the bike out the blue starts to run like this.. i pulled a code tonight of p0134 front oxygen sensor inactive.. what does this mean?
Old Apr 6, 2010 | 10:13 PM
br401k's Avatar
br401k
i'd say go with the vance and hines fuelpak, try that first.
http://www.fuelpakfi.com/harley1.html
generate the input for ur setup and see if that helps. it should do the job
Old Apr 6, 2010 | 11:15 PM
veritas.archangel's Avatar
veritas.archangel
Check ALL of your connections first, before you drop any money. You shouldn't need a FuelPak if all you have is pipes.
Old Apr 7, 2010 | 09:49 AM
83sporty's Avatar
83sporty
what do you mean by all connections? i checked the oxygen plugs.. do you think the oxygen sensor has gone bad? i cleared the code and rode the bike and still the same thing pop pop..
Old Apr 7, 2010 | 10:49 AM
veritas.archangel
I mean check every connection you can find. On the downtube, in front of the side covers are two. My bike did somewhat the same thing, it turns out one of those was loose, the plastic clamp had stretched so it was vibrating loose. Replaced the entire connection, and no problems.
Old Apr 7, 2010 | 12:48 PM
fox4's Avatar
fox4
If you are throwing that code that means the oxygen sensor is either done or not hooked up correctly. If yo follow the harness from the sensor you will come to a connector make sure it is hooked up. Also make sure the oxygen sensor isn't loose.
unkilltony69
Sep 13, 2012 04:53 PM
Sportyzilla
Dec 23, 2011 12:03 AM
Robert Musgrove
Mar 30, 2010 10:06 PM
krismac23
Aug 26, 2008 02:29 PM
rgaskins
Exhaust System Topics
Jul 22, 2007 12:37 AM
