Downshift problem
Old Sep 3, 2006 | 07:28 PM
SportyPig's Avatar
SportyPig
Default RE: Downshift problem
That sounds like a good opportunity to try out your warranty.
Old Sep 3, 2006 | 07:38 PM
clif's Avatar
clif
Thanks Sportypig, that was an option i had considered but they usually find a way to beat you on the money anyway so i thought i would try and find a little info from someone who knows a little more than i do.
Clif
Old Sep 3, 2006 | 09:12 PM
clif's Avatar
clif
Hi Sportypig, is that your HD in front of the post office?Good looking bike! Mine looks just like yours except it is orange and black.
Clif
Old Sep 3, 2006 | 09:30 PM
boom215's Avatar
boom215
i would just downshift by going into the gear and engine break. leaves you in gear just in case.
Old Sep 3, 2006 | 09:54 PM
bikecop40's Avatar
bikecop40
Wow, new to me just going through the forums and came across this! what is "blip throttle down shifting ? do you still hold the clutch in as you down shift? I had the same thing happen to me and just worked the clutch a bit and went into gear
Thanks all
Old Sep 4, 2006 | 01:34 AM
XL OCD's Avatar
XL OCD
As others have said, marcus your problem isn't a problem - it's normal. As you're approaching a light or stop sign, use a combination of hold the brake, clutch-downshift-release, slow, clutch-downshift-release, slow, clutch-downshift-release, etc. Let's the cages both hear and see you slowing. It's what I call a win-win.
Old Sep 4, 2006 | 01:56 AM
Tralfaz's Avatar
Tralfaz
Hmm. I had gotten into the habit of just pulling in the clutch, downshifting to first and coasting up to the stop. I'll have to try releasing the clutch after each shift.
I had noticed the issue that folks are mentioning here a few times and was always curious about it. All of what was mentioned in here was very good information to know.
Old Sep 4, 2006 | 09:49 AM
whaap's Avatar
whaap
blip throttle shifting is just another word for "double clutching". Totally unnecessary. Just shift as you slow down at a slower speed and end up in first gear just before you're stopped.
Being in first gear when stopped is also a safety issue. Keep your eye on your mirrors when stopped and if the guy behind you looks like maybe he won't stop in time, scoot off to the side of the vehicle in front of you. That is if you left enough room between your front and his rear to enable yourself to maneuver.
Old Sep 4, 2006 | 10:54 AM
jshall755's Avatar
jshall755
ORIGINAL: whaap
That's not my understanding. I believe all they are talking about it matching engine RPMs to the lower gear you are shifting to. You simply pull in the clutch, downshift, give just a touch of throttle, and release the clutch. This reduces the amount of engine braking that occurs when engaging the clutch since the bike's momentum doesn't have to raise the engine RPMs from idle. It really just results in smoother downshifts and I do it on my bike and in my car.
Here is an explanation of double-clutching for anyone who is interested: http://en.wikipedia.org/wiki/Double_clutching
Old Sep 4, 2006 | 12:24 PM
whaap's Avatar
whaap
ORIGINAL: jshall755
ORIGINAL: whaap
You're right. I stand corrected.
