'94 883 pully change
Old Jul 16, 2010 | 04:34 PM
mmuth1's Avatar
mmuth1
If I change the drive belt pulley, will I need to change the sensor so the speedometer reads like it should, or is this not an issue??
Old Jul 16, 2010 | 04:51 PM
camcarvin82's Avatar
camcarvin82
883 stock is 27 go with 1200 29 tooth is plenty good enough
Old Jul 16, 2010 | 09:47 PM
XLCR4GM's Avatar
XLCR4GM
Yes, the speedometer WILL be off. I used a re-calibration unit from Dakota Digital at about $100.00 or so to solve the problem. It was VERY easy, sort of a plug and play kind if thing. I do not know if changing the sensor would make any difference because the transmission gear ratios are different on the XL1200 and the sensor is just reading a pulse. Good luck with the change and ride safe out there!
fwb35
Jun 21, 2013 08:09 PM
gilmour68
40
Apr 22, 2013 06:33 PM
Hitechluddite
Aug 3, 2012 12:54 PM
gilmour68
Apr 8, 2009 11:30 PM
jsned
Mar 11, 2007 10:37 PM
