04 Carbed Coil Relocation
Old Jan 14, 2011 | 07:49 PM
Mike07FLHTC's Avatar
Mike07FLHTC
I cast a cover for my boys bike and moved it to the left side.We also did a tank lift and moved the switch with the coil.
Old Jan 14, 2011 | 10:38 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
That is really cool looking. Nice work.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Jan 15, 2011 | 02:35 PM
Mike07FLHTC
Thanks. one of the few perks working in an aluminum foundry for the last 25 years.
Old Jan 15, 2011 | 05:55 PM
HarleyScuba's Avatar
HarleyScuba
I came across a pic with the choke **** re-routed to the right behind the air cleaner, moved his horn to the front down tubes and placed the coil where the horn used to be, with no horn cover, just the coil on the left.
Let us know how you end up.
Old Jan 16, 2011 | 11:02 AM
streetfighter06's Avatar
streetfighter06
Old Jan 16, 2011 | 07:57 PM
gilmour68's Avatar
gilmour68
Any other photos of how this is mounted? Not a bad place for the choke!!!
Old Jan 16, 2011 | 08:49 PM
mreed's Avatar
mreed
There are a few different carb tops & mounts. Here's one from J&P
http://www.jpcycles.com/product/402-702
And a carb top mount
http://www.jpcycles.com/product/403-418
Old Jan 19, 2011 | 08:02 PM
gilmour68's Avatar
gilmour68
That gives me some ideas!!! Thanks mreed
Old Jan 22, 2011 | 01:43 AM
Sarin's Avatar
Sarin
Heres what I came up with on my 05....
Decided on placement position, would have liked to mount it a little higher but had to put it at this height for the electrical connection on the rear of the coil. Fabbed a bracket out of 1/8 steel plate. It bolt on using the original two hex screw that held the choke bracket. I had to make a notch in the bracket for the electrical connector. drilled matching holes in the coil mounting plate. The enricher was relocated using the original bracket, drilling a hole in the center(between the small screw holes). I cut and rounded the bracket base to eliminate the two small holes(mainly for looks). The bracket bolts to the hole which had the plastic plug wire clip. this hole was already threaded for 5/16, just had some powder coat build up. The **** kind of comes out at a slight angle to the back to clear rocker box, that dont bother me, but some may not like that look. When I was checking for plug wire length, I found the choke slightly interfered with the plug wire so I just moved it to the underside of the large bracket and that solved the problem. I modified my stock wires to fit by carefully loosening the crimp, cutting to length (spark plug end) as they were cut from factory and recrimping. I think they should still function fine as they went back together as they were before, but i wont know as im still awhile from starting her up. I will prob fab up some kind of cover for the coil as i feel it looks somewhat plain. Ill run the electrical wire up the back of the bracket and bring it up under the tank with the vacuum sensor wire from the carb. The brakets will be painted when I paint the other items i have fabbed or modified during the winter projects. Hope this helps someone. BTW, Please excuse the plastic bags, hanging wires, and other mess as im doin many other things to the bike as well, lol.
Old Jan 22, 2011 | 04:46 PM
HarleyScuba
That's some nice bracket fabrication.
DR. V-TWIN
Sep 7, 2010 11:16 AM
chromedome
Jul 3, 2009 05:44 PM
kd4tsc
Apr 29, 2009 02:49 PM
tnt0303
Jul 26, 2008 02:07 PM
4merRacer
Dec 24, 2007 07:13 PM
