sparks 'n stuff
Old May 14, 2010 | 02:50 PM
ElGoonski's Avatar
ElGoonski
Default sparks 'n stuff
Hey everyone!
So I was riding my 08 nightster the other day, and the engine was occasionally sputtering a bit while at cruise speed. Maybe not so much of a sputter, but just instantaneous 'hickups'. It didnt happen alot, but I stopped to check the gas. It was good, but I topped her up and when I started it up again the old lady told me there was a bunch of sparks when the ignition occured. So I shut it down and she showed me that the sparks came from directly behind the rear exhaust pipe, where it meets the engine (or exhaust port). So I inspected the area, and saw no chaffed wires or burning. It started up again with no issues. When I got home, I let it sit for a few mins and the sparks occured once more. I couldnt get it to do it again. I checked the pipe bolts and they weren't tight, but I cant imagine that causing sparks. Unless the sparks are burning bits of carbon being blown out???
Any help or ideas how to troubleshoot this would be fantastic! Thanks in advance fellas.
Old May 14, 2010 | 02:54 PM
NSCoyote's Avatar
NSCoyote
Originally Posted by ElGoonski
Hey everyone!
check headgasket leak or blown out. my ironhead would spits sparks out if the joint betwen the heads an cylinders when it blew the head gaskets
Old May 15, 2010 | 05:12 AM
ElGoonski's Avatar
ElGoonski
Thanks man, I'll check that for sure. I'd be really suprised, as its only got 3200 miles on it... but I cant discount anything at this point. Although the sparks do look cool, they are usually bad when on the OUTSIDE of your motor!
Has anyone ever heard of this problem with nightsters?
PS, whats the best way to check for the leak? Compression check, or just feel around for hot air when the engine is cold?
Old May 15, 2010 | 05:41 AM
cHarley's Avatar
cHarley
Hey everyone!
Re-torque the exhaust nuts to spec and see if that fixes it. If not, remove the pipe and replace the gasket.
Old May 15, 2010 | 05:42 AM
xFreebirdx's Avatar
xFreebirdx
Make sure your battery is not shorting out in the battery box. (Or any other shorts). A couple years ago my battery shorted and my brake line started shooting sparks like mad just before the brake line bust into flames.
Old May 15, 2010 | 07:15 AM
Quadancer's Avatar
Quadancer
YOW, man, that's SICK!
Yeah, OP didn't describe this exactly, but it does sound like a loose head or blown gasket. Lemme tell ya, I pulled down a head on a fairly new FB that developed leaks. It looked like the assembler just THREW the box gaskets on there; didn't even TRY to line up at all. New gasket; no problem.
Old May 15, 2010 | 07:42 AM
xFreebirdx's Avatar
xFreebirdx
Yea your right about the description. To me sparks are sparks. I would think flames would come out by the exhaust gasket.
I thought I would just toss the issue I had out there.
Old May 15, 2010 | 07:54 AM
cHarley's Avatar
cHarley
I'm sure you've removed a header gasket or two in your day, and that you know that when you rip them out and they pull apart you realize they are essentially made of compressed steel wool. Ever put a torch to steel wool?
Not to mention that the stock, oversize non SE gaskets, trap a bunch on carbon on their edges.
I'm not saying that's his problem, but I wouldn't rule it out.
Old May 15, 2010 | 08:14 AM
xFreebirdx's Avatar
xFreebirdx
Makes perfect sense.
Old May 15, 2010 | 10:09 AM
ElGoonski's Avatar
ElGoonski
Default aw man
Well thanks for all of the input guys... I'm not too happy with the fact that I may have a bad head gasket, but I never even thought of the 'steel wool effect' either! I've got the bike stripped down so I'll take a closer look at both the head AND the battery wires.
Blast, just when I thought buying a NEWER bike would buy me a few years of not dealing with this kind of non-sense.
I'll post what the fix is when I figure it out
