Risers installed with Mini Apes
Old Jun 2, 2010 | 09:03 PM
HOGKID84's Avatar
HOGKID84
Originally Posted by 09WDHGS
Custom Chrome makes both black and chrome straight and curved risers reasonably priced.
yes thank you, affordable would be great
Old Jun 3, 2010 | 10:28 AM
flatheadfreakv8's Avatar
flatheadfreakv8
1st Gear
Licks cycle has a lot of risers and the price is really good
Old Jun 3, 2010 | 08:50 PM
medic2931's Avatar
medic2931
What size are the stock ones on an Iron? I have 8" Road 6 Custom apes and would like to go up a little. Thinking about 3.5" risers. Stock are what, about 1?
Old Jun 3, 2010 | 10:32 PM
gr8stdane's Avatar
gr8stdane
I have an 09 Iron with the harley mini apes and licks 3.5" straight risers, and the only cable I replaced was the brake cable. The others are a little tight but still fit. My gas tank is raised about an inch and a half, so the top clamp is now level with the top of the gas tank, so it looks good.
Old Jun 6, 2010 | 08:34 AM
medic2931's Avatar
medic2931
I like the look of your setup. Think I'll have to order a set of licks risers for my Iron. Should have just gone with the 12" Apes but I didn't want to change all the cables. Guess I'll see if they still work with the risers. I already swapped out my brake line.
Old Jun 6, 2010 | 06:32 PM
dragon78's Avatar
dragon78
Bruce- Do the handlebars feel like they move back and forth. I just installed 12" ape with 4" risers and I get this movement. I took it out around the nieghborhood and when ever I came to a stop, it felt I was going to bend the bars off the motorcycle. The riser bolts are tight.
Old Jun 6, 2010 | 07:48 PM
lilbruce's Avatar
lilbruce
Hey they have no movement.... Do you have a pic of your setup....
I like the way mine feels and what type of movement are you talking about
Old Jun 6, 2010 | 08:02 PM
ernofsteel007's Avatar
ernofsteel007
Originally Posted by HOGKID84
Hey everyone,
Looking for some guidance, I am interested in throwing on some risers with my mini apes. Just to give em' lil more heigth but not sure how tall I should go with the risers thinkin maybe 2" also I'd want to go with the straight risers? what would be some good risers I could check out.
Thanks again, I'd like to do this soon
yeah ebays your friend, lil bruce has 5 inchers that look great, i think any riser is better than apes on stock risers.
Old Jun 6, 2010 | 09:16 PM
lilbruce's Avatar
lilbruce
Thanks for the comment
Old Jun 6, 2010 | 09:24 PM
MJ's Avatar
MJ
I have 4" risers with my mini apes and can't imagine them being any lower or higher. Please use the poly bushings and not the rubber ones when you do the install.
