Next Step for Stage 1 Conversion
Old Aug 18, 2006 | 02:37 PM
SportyPig's Avatar
SportyPig
Default Next Step for Stage 1 Conversion
I added Cycle Shack Slips on to my '06 883. Now I want to replace the a/c and I guess rejet the carb. Looking for some suggestions. Specifically, if someone has the same pipes on an 883. That will help with all the trial and error especially in the carb rejetting. Since those 3 function pretty much together, I figured if someone already has a great working combo, I could save me from making a mistake. Thanks!!
[IMG]local://upfiles/15448/18685B4228E84B21B7AC414785050327.jpg[/IMG]
Old Aug 19, 2006 | 08:55 AM
bigtop's Avatar
bigtop
Default RE: Next Step for Stage 1 Conversion
Hope I can help. I have a stock ac. I added a series of holes to the back plate for more air. I have tried the 46 idle jet but, am now using a 48 because of continued carb coughing. I have the 180 high speed main jet in it (from a stock 170). I have the cycle shack slip-ons. I think I have the right combo now. Plugs are clean. I am getting 54 miles per gallon of gas. The only thing that I notice is that starting is a problem now. I have to use the enrichener sparingly. I'm happy. Ride on friend.
Old Aug 19, 2006 | 07:21 PM
SportyPig's Avatar
SportyPig
Thanks man!! all info is appreciated. I think if we can continue to share this type of information, it will save us all some $$$$
Old Aug 19, 2006 | 10:16 PM
DieHard's Avatar
DieHard
Hey there i also got the cycle shack slash cut slip ons and i bought the jet kit from sorgy'y on ebay it came with a 45 slow jet and a 180 main jet and 4 new 3mm hex screws for $12.94 and a screaming eagle air cleaner kit from dealer. i rejetted with the jet kit, drilled and remove plug from air fuel mixture screw and set it at 2 turns out runs perfect. and i'm using and older type air cleaner cover instead of the new type. she runs sweet.
Old Aug 20, 2006 | 01:46 PM
SportyPig's Avatar
SportyPig
Thanks a ton man, that's exactly the type of info I was looking for.
Old Aug 21, 2006 | 03:21 PM
Sporthawg1200's Avatar
Sporthawg1200
Bigtop,
Do you have pics of those holes you put in the backplate?
Old Aug 21, 2006 | 06:46 PM
bigtop's Avatar
bigtop
No I don't. Look at the form of the filter. Drill 1/4 inch holes in a sequence on the back plate according to its configuration. Don't drill so many as to weaken the integrity of the plate. Try to do it with some art and form to it so it looks good.
Roni
Jul 27, 2012 04:43 PM
brians777
Jul 15, 2011 05:47 AM
jered
Feb 16, 2010 11:37 AM
clayman
Sep 23, 2006 02:18 PM
Sally88
Jun 28, 2006 01:22 AM
