springer front
Old Aug 20, 2006 | 01:43 AM
wvtommy's Avatar
wvtommy
Default springer front
has anyone put a springer front on there sporster i think that would look cool?
Old Aug 20, 2006 | 01:52 AM
OldFenderGuy's Avatar
OldFenderGuy
Default RE: springer front
This Sportster was built by the custom shop that does work on some of my bikes...
Old Aug 20, 2006 | 01:56 AM
wvtommy's Avatar
wvtommy
hate to ask but what did the front cost and i guess they had to do something to fit that large tire in bike looks real good
Old Aug 20, 2006 | 02:08 AM
OldFenderGuy
ORIGINAL: wvtommy
Well, the cost really depends on if you are building a 'ground up chopper', or if you want something engineered to work with your stock frame without any cutting and welding.
You can get a TUV and DOT approved Springer front end (14 degree additional rake for a total of 44 degrees) that is engineered to work with your stock frame and neck geometry. The "kit" adds rake to both the neck angle and the tree angle, which offset each other so you end up keeping the stock trail dimension. You can't really add rake to just the neck or tree alone, or your 'trail' could be increased, or decreased to the point high speed stability and handling could become dangerous.
Anyway, complete Springer kits aren't cheap, and cost about $2,600 for everything needed in one complete package.
Of course, if you go with a "complete ground up chopper" you could be talking somewhere in the $10,000+ range.
Old Aug 20, 2006 | 02:15 AM
wvtommy's Avatar
wvtommy
well i just like the look of the springs maybe can bolt some fake ones on would get some head turns from a distance
Baxy2112
Jun 28, 2013 08:07 AM
Ragnar Danneskjöld
Feb 23, 2011 07:32 PM
sorensentyler
Feb 15, 2010 04:25 PM
jtbredneck351
Ironhead
Apr 9, 2009 12:46 AM
hangman987
Nov 4, 2006 12:21 AM
