so over the last month or so my bike 07 sporty has developed an intermittent engine light issue. my speedo stops working, and the bike runs terrible and idles just as bad even stalls at times. i have done the self diagnostics thru the speedo and found it has 3 fault codes in it. p0132 p0152 and p0505.
the codes lead me to believe its a wiring issue, so yesterday i tore me seat off pulled the baattery, fuel pak, and the back half of the wiring harnness along with the ecm, after spending a few hours inspecting the wiring and coming up empty handed i decided to put it all back together and ask you guys if any of you have ran across these codes before
Well the first two are for your front and rear O2 sensors, but the 505, I don't think there is a 505. Do you have your O2 sensors connected, or do you have some foolers in their place?
according to the sticky the p0505 is a loss of idle speed control, and the p0132 and p0152 or ft and rr o2 sensor circuits high. i was mostly curious if anybody has ran across these and if so where they found the problems. in cars at least these codes usually indicate a wiring issue. and would figure the same in a efi bike
