Cable Lubricating??
Old Jul 29, 2010 | 07:33 PM
Razorback Rob's Avatar
Razorback Rob
Default Cable Lubricating??
Hey guys. I hope everyone has had a safe riding season. I hope all is well. Here lately my throttle cable, or idle cable has been sticking. When I let off it doesn't snap back like it should. I put the cables on last August. Do you think they need some lube? And does one go about that?
Old Jul 29, 2010 | 08:07 PM
trozenhorse's Avatar
trozenhorse
probably need an adjustment and perhaps the throttle body where the cables connect may need some wd40 on the spring that makes it snap back
Old Jul 30, 2010 | 01:50 AM
Gpsjr10's Avatar
Gpsjr10
Make sure the thumb screw (throttle lock) under the throttle grip is loose.
Old Jul 30, 2010 | 02:53 AM
XLCR4GM's Avatar
XLCR4GM
Hey Rob, Graphite works very well and there are also bottles of cable lube that you can buy from the dealer or Cycle Tech or other similar shops. Some of them come with an applicator to help make it easier to lube the cables with. It never hurts to lube the cables and if you haven’t done it yet NOW would be a good time to do it. It may or may not solve your problem but it sure won’t hurt it either and it is something that needs to be done regularly. Give it a try and see what happens. Good luck with lubing the cables and ride safe out there Rob!
Old Jul 30, 2010 | 09:06 PM
Razorback Rob
It's not the thumb screw. I've learned that lesson before. I'm going to pick up some lube tomorrow. I'm going to check the adjustments and go ahead and lube them. They just uncrated a Super Low. I'm anxious to see it.
twistedcherokee
Mar 25, 2016 07:39 AM
bigpappa160
General Topics/Tech Tips
Feb 4, 2016 10:49 AM
msamarah86
Jun 22, 2011 07:34 AM
98sportyil
Jul 30, 2008 08:18 AM
