Please post correct information
Old Aug 15, 2010 | 06:49 PM
svcami's Avatar
svcami
Old Aug 15, 2010 | 07:04 PM
Grammaton's Avatar
Grammaton
Originally Posted by svcami
Case in point: Recently a question was posted on how to check oil level on their Sporty. Several of the posted replies emphatically stated the oil should be checked while the Sporty is on the sidestand.
Please review the exerpt below from my service manual:
I didn't see the thread you're referring to but my manual says to check the level while the bike is leaning on the jiffy stand.
Old Aug 15, 2010 | 07:11 PM
95th 1200's Avatar
95th 1200
My owners manual (1998) also states
"All motorcycles except Softails and Sportster models should be on the jiffy stand. Softails and Sportster models should be upright and level. Wipe off dipstick and insert into tank with plug pushed completely into filler neck"
Old Aug 15, 2010 | 07:14 PM
TN Back Roads's Avatar
TN Back Roads
Mu 08 manual says to check oil level with bike leaning on jiffy stand on level ground. Don't know what year you have but if you have the owner's manual, why would you even ask. I suggest you check as your owner's manual tells you to. Is the manual you have for your year bike?
Old Aug 15, 2010 | 07:29 PM
cHarley's Avatar
cHarley
A forum can be a very good self help tool. When you post something make sure you are correct in what you state!! Your well ment inaccurate reply may be the cause of injury or damage to a person or their Sporty.
Probably more important is that the poster list the YEAR of the bike in question, and that the readers not assume that it applies to other vintage bikes.
The oil level on all late model Sportsters, is checked with the bike on the jiffy stand.
But then, there is no reason to ask such a question in the first place. If you don't have a Manual for YOUR bike, get one.
Old Aug 15, 2010 | 07:45 PM
svcami's Avatar
svcami
Default Oil Check
Old Aug 15, 2010 | 07:47 PM
tidefan60's Avatar
tidefan60
My 2004 clymer service manual says to check it on the jiffy stand without pushing the dip stick back down.
Old Aug 15, 2010 | 08:03 PM
mreed's Avatar
mreed
You should also understand that this is a forum and not a tech-service information depot.
Ask a question, take it for what it is worth and apply your version to the deed.
I've seen ALOT of information traded here and cannot think of a single time when the poster is not 100% sure they didn't state something along the lines of..."you may want to ask your dealer but I'm pretty sure bla bla bla"...
But something as minimal as checking your oil hardly rates as an issue that will cause personal injury.
Maybe we all need a signature with a disclaimer stating that the information you have just received should no way create a liability by the poster.
If you are reaching out to a forum asking questions about something that can harm your bike or own body, you seriously should invest in a service manual.
Thanks for the heads up though. I can see how it would be easy to get caught up in the world wide web super communication and take it as fact.
Old Aug 15, 2010 | 08:23 PM
Gpsjr10's Avatar
Gpsjr10
The advice given on this or any forum is usually from other member's experiences. If you follow this forum there are many people on here with a ton of experence. (I.e. cHarley and sporty pig come to mind) plus many fabricators, techs and just people with cool ideas. If you follow the forum for a while you can pick out the B.S. very easily. Plus if someone does give bad advice that may be dangerous to your life, it is usually counter posted several times very quickly. For example. Someone posted that they were running a jockey shift with no front brake and it was questioned as to how they deal with stopping on a hill. Along with a solution to the problem. I think that people on here put safety first and that is the way it should be.
Old Aug 15, 2010 | 08:28 PM
xFreebirdx's Avatar
xFreebirdx
Like Ratrod said in another post. In a nutshell, "Spend all that money on a bike and pirate outfit and whine about buying a focking service manual". Its pathetic really.
This is how a ball bounces.
