48 owners
Old Aug 28, 2010 | 07:52 AM
falsealarm's Avatar
falsealarm
Default 48 owners
If you have tried to change footpegs you will know nothing fits the stupid set up harley used. I went to the H-D shop yesterday and asked about changing the peg shaft from another sportster model. Bingo it worked Ordered 2 new shafts. Around 30 bucks apiece. Just thought I would throw this out FYI Have a great day
Old Aug 28, 2010 | 08:23 AM
dusandimic's Avatar
dusandimic
How about some pics?
Old Aug 28, 2010 | 11:33 AM
zRamz's Avatar
zRamz
Yeah, I picked up some Silencer Footpegs and they wouldn't fit. So I just put them in a vice and ground them down a little until they fit.
Old Aug 28, 2010 | 01:38 PM
Pagan48's Avatar
Pagan48
The footpegs on the 48 are offset. How does the change effect your foot position? Wanting to change mine but looking for more info.
Old Aug 28, 2010 | 03:33 PM
falsealarm's Avatar
falsealarm
Default 48 pegs
Don't have them on yet. Will let you know.
Old Aug 28, 2010 | 08:22 PM
cockerhamsg's Avatar
cockerhamsg
Dude I just now ran into this myself! Do you have a part number for those shafts?
Old Aug 29, 2010 | 02:03 AM
KAH24DupontChevy's Avatar
KAH24DupontChevy
Default Footrests are same for Forty Eight and Rocker/Rocker C...
Forty Eight riders: Unless I am off the mark, the offset footrests on the Forty Eight are the same as the ones on the Rocker/Rocker C (rubber pegs offset down and to rear with peg feelers).
Other Harley footrests will fit the forward controls on the Forty Eight; however, placement will lift your foot up and forward. This may change comfort for some.
In some/most cases this also means you will give up your stock peg feelers which stick out from bottom of peg and drag when you hit a certain lean angle.
My take:
1. You will drag hard parts--exhaust, jiffystand, etc. when you lean the bike into a turn. If hard parts touch first instead of feelers, this could lever the rear tire off the ground and could result in a bad situation.
2. Foot placement and riding position will change slightly due to different offset and rise vs. stock footrests.
I'd recommend keeping the stock rubber pegs with feelers until/unless the aftermarket comes up with an offset peg solution.
NOTE: I own a Forty Eight and like the stock pegs as they are on a blacked out bike, but also once owned a Rocker and hated the stock pegs because they were so plain on a chromed sled.
Regards,
Karl
Old Aug 29, 2010 | 08:02 AM
cool granny 48's Avatar
cool granny 48
My husband installed these foot pegs
on my 48 by grinding the longer leg
on the stock shafts (just enough to
get the pin to go thru) I love them &
the heel rests make for very comfortable
riding on longer trips. The change of
position was so little that I never
noticed.
Old Aug 29, 2010 | 08:23 PM
cockerhamsg
I'm not too keen on grinding those nubs off.
Old Aug 31, 2010 | 11:33 AM
cockerhamsg
What year were those peg shafts for?
