Shock adjustments?
Old Sep 10, 2010 | 09:41 AM
warrick's Avatar
warrick
Default Shock adjustments?
I just got some progressive 412's on my Iron, seem a little soft. Any suggestions on adjustments (how is it done). I am not very big (135 lbs).
Where do you guys have yours set?
Is my best bet, just keep adjusting one notch at a time til it feels right.
Sorry for the newb question, never done anything with any kind of suspension.
Old Sep 10, 2010 | 10:03 AM
cHarley's Avatar
cHarley
That's what I would do.
Old Sep 10, 2010 | 10:05 AM
warrick's Avatar
warrick
I went through my box of stuff and found what appears to be a wrench to adjust them. Anything special you need to do, or just clamp on and turn?
Old Sep 10, 2010 | 10:12 AM
Steeler's Avatar
Steeler
Default Howzit
I had a look at the specs and they boast a 5 stage adjustment,yep you should have got some type of wrecch to adjust,Download the manual on the shock if they didn;t incude it in the box.
Ok genrally this aplies to conventional shocks,you just rotate the shock with the tool to the adjustment you want ,you can do this while the bike is on the side stand ,just make sure both shocks are set to the same setting .so if they are to soft click one notch for a firmer ride,take the tool with you on the ride and play around with the settings untill you have the one you like.H
Old Sep 10, 2010 | 10:20 AM
warrick's Avatar
warrick
Excellent, something to do this afternoon.
Thanks!
Old Sep 10, 2010 | 10:43 AM
wanabe's Avatar
wanabe
make sure that you are starting in the right setting... i wouldnt start in the 2 up setting and go one notch at a time- my recollection is that the one up setting is the one that looks like it should be the 2 up (the 2 up is the one where it looks like the spring travels the least)
drnk_n_publick
Apr 28, 2009 05:44 PM
fixedmlc
Mar 23, 2009 08:22 AM
jsbridgew
Jul 31, 2008 07:18 AM
fendrix
May 10, 2007 10:52 PM
supermario
Feb 20, 2007 06:01 PM
