did i get ripped off
Old Sep 26, 2010 | 12:22 PM
streetfighter06's Avatar
streetfighter06
Dude - If it's only 3 years old and it needs a clutch, someone beat the **** outta that thing. If the back tire looks new then I'm right on the money.
Old Sep 26, 2010 | 04:44 PM
Brett001's Avatar
Brett001
I would take it apart and see what is hosed before buying parts.
Maybe its just the rivet problem and you need one plate, or the cork sets.
Too busy to do it yourself, but no problem to pay someone $800.00....
2 hour job? you make more then $400.00 an hour?
Too busy, its a 2 hour job maybe, but you will ride to the dealers, get a ride home, then get a ride to the dealers when its done, and ride home....
Depending on what is wrong, I bet you can get the parts way cheap, whats the SE clutch kit cost anyway?
I am sure there are loads of people making clutch stuff for Harleys, and without the dumb rivets.
Brett
Old Sep 26, 2010 | 04:46 PM
HOG_0308's Avatar
HOG_0308
wow that 60 bucks for a manual would have paid for its self with this fix...
Old Sep 26, 2010 | 05:13 PM
Zenmervolt's Avatar
Zenmervolt
You're missing something here. The dealer's labor rate is $62/hour, not $400. The dealer is charging him for 1.5 hours of work, so a total of $93 in labor.
That means $707 of the total price is parts. Parts that he'll have to buy regardless of who does the work.
Old Sep 26, 2010 | 05:20 PM
Guest
Guest
Posts: n/a
The manual is available online (so I hear, but I have one, so I haven't looked for it), but you can get it at the dealership.
Old Sep 26, 2010 | 05:37 PM
Jeff W's Avatar
Jeff W
Some people just are not comfortable wrenching some things on thier own,,if they are not comfortable or confident then by all means take it to a shop of your choosing and have them do it for you, nothing wrong with that at all.
I still think you should get a manual and bigin learning, even if its a little at a time here and there. Start with small repairs and work your way up as your confidense builds.
Old Sep 26, 2010 | 10:26 PM
Brett001's Avatar
Brett001
And how would anyone know if he needs all those expensive parts?
If he was to take it apart and find the rivets came loose (if he has them), then cant you just get the SE clutch kit, or one of the other kits, and have a better clutch for half the price?
If someone does not want to work on bikes, then they should just say so, but unless the shop is next door, I think it takes more time to take the bike someplace.
Its easy to fit a job in between all the other stuff we have to do.
Step one, drain primary oil (5 minutes?)
Step two, take primary cover off (10 minutes?)
Step three, look at clutch and operating gizmo (2 minutes?)
Etc.
You don't have to do the job in one shot...
The manual makes it step by step easy, have a cold one, put the tunes on, and do manly stuff in the garage, is anything better?
Brett
Old Sep 26, 2010 | 10:28 PM
Brett001's Avatar
Brett001
Look at these prices for clutch stuff!
http://www.jpcycles.com/search/searc...02800%20274461
Old Sep 27, 2010 | 03:56 AM
Osco's Avatar
Osco
Account Deactivated
Get the HD manual from the Dealer! It's more detailed and accurate than the knock off's.
Manual, clutch, n a tool or two,,what,,, 300 bucks? I'm guessin here.
Whats your time worth,,I'd spend a few hours In the garage to save 4 or 500 bucks.
Thats alot of beer money.
Old Sep 27, 2010 | 08:12 PM
Zenmervolt's Avatar
Zenmervolt
$827.99 for a full kit like the dealer is offering for $800 including labor.
If the dealership is lying about what parts need to be replaced, that's one thing, but in my experience that's very, very, very rare. You're starting from the assumption that the dealership is replacing parts that don't need to be replaced and that there are parts he doesn't need and there's no basis for that.
If we assume that the dealership's assessment of which parts need replacement is accurate (and 9 times out of 10 it is) then the only appropriate cost differential is the labor expense of $93.
