time to rebuild?
Old Oct 3, 2010 | 09:56 PM
pleasants9's Avatar
pleasants9
yup I have the Harley factory service manual, I ask to make sure because the manual assume the motor is going to be taken out for all engine work. I plan to spend the whole weekend on this project aside form saturday night for the LSU game. Since I will be removing such things, should I get anything new to replace aside from just gaskets, and honing the cylinder
Old Oct 4, 2010 | 06:30 AM
woodworking1's Avatar
woodworking1
Gaskets and assembly lube should be all you need.
Old Oct 4, 2010 | 11:10 AM
WVHogRider's Avatar
WVHogRider
You're making this too complicated. I'd just replace the leaking gasket(s) & be done with it in under a couple hours. IMHO, Nothing you've stated warrants a rebuild, new rings, honing of cylinders, etc. Just my though.
Edit: Oh, if you want those aluminum covers to look almost exactly like chrome.....Sand & polish them.
Old Oct 4, 2010 | 08:08 PM
pleasants9's Avatar
pleasants9
WVhogrider, thanks for the input, the reason im going so deep into it is it the base gasket has signs of leaking as well, so If I am going to be taking up the cylinder to put a new gasket in, I figure I mine as well clean up the cylinder while im in there. The bike is '92 and the engine has never been messed with to my knowledge. I am not going to mess with the valves, so I shouldnt have to worry too much about timing hopefully.
FunGramps
Jul 17, 2017 01:43 PM
95 Ultra
EVO
Nov 12, 2012 10:00 PM
travisd
EVO
May 3, 2009 08:19 PM
lankester
EVO
15
Oct 6, 2008 05:26 AM
Shinysideup
Exhaust System Topics
Sep 18, 2008 05:41 PM
