So my passenger felt something hot periodically stinging her leg while we were riding the other day. When she got off she had black splotches on her leg, oil.
So it would seem I have a blown head gasket, to confirm, I did a compression test on both cylinders. I was getting 75psi in the forward cylinder and 70psi in the rear cylinder, shouldnt it be at about 100psi? Is it time to just do a whole top end rebuild? My buddy said I should be able to do it with the engine still in the bike, just take the tank off. my bike is a '92 sportster 1200.
part B of the question. If I do take the cylinders off, the finish on them is all gone, should I go to get them chromed or use that wrinkle/crinkle paint on them?
How many miles?
You should get at least 100,000 miles before needing a rebuild if you took care of the bike.
You might just need a head gasket.
Did you check the head bolts?
You can definitely do it with the engine still in the bike. To confirm your problem, you should do a leak down test. could have just been off the bottom of the air cleaner. You have to remove your tank,pipes,carb, a few motor mounts and the such. It's a fairly easy job. Your best friend will be a good torque wrench and patience. That rear rocker cover only comes out 1 way. Unless you have a bigger problem, you should be able to just do a gasket replacement.
How many miles?
Brett
Couldn't tell you how many miles, I haven't had a speedo or any other gauges on the bike in 5 years, just a dipstick thermometer in the oil sump is my only gauge. I take good care of the bike but I use it frequently, probably start it up 3-5 times a day, I go to school here at UF so I use it back and forth from classes and around town, it gets a lot of use. And i thought the oil was just from the air cleaner too till I saw a light film of oil all around the gasket area. I think I am gonna dedicate all of next weekend to this project, unfortunately I have all my tools 4 hours south at home, so I will probably have to pick up something at harbor freight to get me through it.
As of right now, I have a standard/metric socket set that goes up to 13/16 /19mm, the compression tester I just got, wrenches both metric and america, allen wrenches. I know I need to get my hands on a torque wrench for the project, also ring compressor to put the new rings on the piston. What else should I get my hands on before starting the project? I have a manual also so that should be good to, and I will definitely get some crinkle pain to redo the cylinders, are they many brands of that stuff?
your compresion does sound a little low,but there are so many varibles to get a good reading. but the oil isnt blowing from the head gasket, little to no oil in there, it is coming from the rocker box or aircleaner if anywhere
Just to make sure, I should be able to do all this without removing the engine correct? All I have to do is remove the tank and although it will be a tight clearence, the rockers, heads, and cylinder will all come out?
YES! Do you have a manual? It's a definite for a project like this. You will have to remove the air cleaner, carb, both pipes, a few motor mounts, intake manifold, coil, plugs and wires, a little ground wire attached to the left rear of the tank bottom, and a few other misc. fasteners. Take your time, label your parts, and enjoy!
