won't start
Old Oct 2, 2010 | 09:46 PM
Cavi's Avatar
Cavi
Default won't start
okay, I just picked up my 87 883 this week, went to change the bars, and encountered some messy wires in the switch pod, I fixed the ones that were loose, but the bike will not start. someone had messed with the wires alot before, and when I removed the pod to install the pod two wires had come loose, so I fixed them, but it still will not start. I am thinking that maybe I blew a fuse, but I do not have a manual yet, are the fuses under the seat or in the headlight? Sorry if this is a dumb question, but I promise to get a shop manual this week.
Old Oct 3, 2010 | 12:19 AM
Cavi's Avatar
Cavi
Also if anyone has a wiring diagram and can tell me the wire colors for the starter bottom and the kill switch
Old Oct 3, 2010 | 07:44 AM
Steeler's Avatar
Steeler
Default Howzit
well if your fuses are positioned similiar to the nighster ,they are behind the batery side cover,also we have a master fuse positioned seperatlly with a bigger fuse.
Old Oct 3, 2010 | 11:32 AM
Cavi's Avatar
Cavi
in the battery area I do not have fuses, I have one normal relay and 4 smaller smaller retangular relays( at least they look like relays)
I am going to either redo most of the wiring near the switch pod , get a manual to see what wire I am looking for or take it to the shop. The wireing in the pod area is a mess and when I took it apart it did not help
Old Oct 4, 2010 | 01:38 PM
TommyTheKat2010's Avatar
TommyTheKat2010
From: Colorado Springs, Colorado... I'm originally from Denver.
Might be under the seat. I have an '87 Sporty and an '88 Sporty. There's at least 1 fuse under the seat that I've seen. It's attached by a small screw to either the frame or the inside of the oil tank cover (underneath the seat). I had the same problem of not starting with my '87.
Old Oct 5, 2010 | 02:00 PM
Cavi's Avatar
Cavi
end result, it is going to the shop for some other work so I am pting for them to replac the harness to that side, since it is soo butchered anyway...
cohcdt
Feb 27, 2024 09:30 AM
Blk80bike
Electrical/Lighting/Alarm
Sep 25, 2016 08:09 AM
dsanchez7562
Apr 14, 2014 07:05 AM
obediah01
Jun 4, 2011 04:24 PM
dr.phatkins
May 1, 2007 09:12 PM
