battery ground wire
Old Oct 15, 2010 | 08:10 PM
btamburro's Avatar
btamburro
Originally Posted by bmorebhoy
I cut the open end off the proper size combination wrench. Fits well in the tool bag as well.
Yup i did the same thing, ended up with a stubby 12 pt box end wrench that fits perfectly in between everything in the way so I can loosen or tighten that nut 1/8th turn at a time. There is a diagram in the owner's manual for the set-up that is supposed to work but, no combination of socket/extension/wobble extension/u-joint/ratchet worked for me.
Old Oct 15, 2010 | 10:07 PM
Dango's Avatar
Dango
Originally Posted by deepsea
Got a question for you gray beards. How do you get a wrench on the #$%^&#! nut connecting the ground wire to the engine case? Between that and torx head bolts someone needs their *** kicked!
There are numerous tight spots on motorcycles but I couldn't agree more- someone does needs their *** kicked because of this ground wire placement...and torx bolt idea. I hear ya deepsea.
Old Oct 15, 2010 | 10:25 PM
Aaron48's Avatar
Aaron48
Yes the combo of Torx, Allens, and normal hex bolts its a bit on the *** kickin side of engineering
Ms54Coupe
Mar 5, 2013 06:49 AM
Cougar1959
Sep 7, 2012 03:28 PM
aahmes57
Jun 12, 2012 06:35 PM
wolfman 66
Dec 21, 2011 08:58 PM
veniculum
Oct 19, 2011 10:59 PM
