negitive batery wire
Old Dec 20, 2011 | 10:21 PM
wolfman 66's Avatar
wolfman 66
Default negitive batery wire
How do you get to the ground wire under the starter. I have tried every wrench i have. I can't get my hand in. sockets are too tall combo wrench
is wrong angle. Do i have to remove the battery box to get to it?
Old Dec 20, 2011 | 10:39 PM
hatchetman's Avatar
hatchetman
Are you able to drill a hole in the battery box so you can get a socket right onto it???
You can make a big hole cause the battery will never fall through it!
Hatch.
Old Dec 21, 2011 | 09:57 AM
Lowcountry Joe's Avatar
Lowcountry Joe
I like Hatch's idea. Removing the battery is an inconvenience for sure, but worth it when you can avoid a lot of other aggravation. Probably a good idea to inspect your battery terminals and clamps anyway. Plus you will be assured that you can properly torque that connection once you re-install.
Old Dec 21, 2011 | 10:03 AM
wolfman 66's Avatar
wolfman 66
The nut is to far under the starter to get a socket on. Looks like i will have to make a wrench or take the tray all the way out.
Old Dec 21, 2011 | 10:08 AM
X Iron Butt's Avatar
X Iron Butt
That is not a ground wire. The starter grounds when it bolts to the primary. The bottom wire is what powers the motor when the solenoid is pulled in. The only wire you need to disconect is the one on top coming from the battery. IT IS HOT so disconect it from the battery first. The lower wire will come out with the starter moter assy. SEE service manual.
Old Dec 21, 2011 | 12:33 PM
speakerfritz's Avatar
speakerfritz
I'm not at the house...but I removed it from the right side (opposite of primary) using basic tools. Have an 07.
Old Dec 21, 2011 | 12:59 PM
wolfman 66's Avatar
wolfman 66
It is the ground wire from the battery to the top of the tranny under the starter.
Old Dec 21, 2011 | 04:06 PM
X Iron Butt
Sorry wolfman thought you were trying to undo the power wire. It is pretty far under there and can't really get to it with the starter installed. I don't have that ground on my bike.
Old Dec 21, 2011 | 08:58 PM
krazy3's Avatar
krazy3
Same here
Rusty Axle
Shovelhead
Apr 18, 2020 07:20 AM
Kcougar
Nov 19, 2018 12:22 PM
unluckyluke
Electrical/Lighting/Alarm
Aug 10, 2017 10:12 AM
hoopdog9
Jan 9, 2013 09:33 PM
98king
Jan 7, 2008 12:35 PM
