Problem with nightster!
Old Oct 15, 2010 | 04:21 PM
stebbins17's Avatar
stebbins17
Default Problem with nightster!
okay so i have an 07 nightster and its been riding kinda of rough lately mostly with shifting it feels like its jerking forward when im riding. any suggestions on what might be the problem. also i just had the primary tightend.
Old Oct 15, 2010 | 04:31 PM
Guest
Guest
Posts: n/a
Does it do it all the time, or just under certain conditions? If the latter, what are the conditions? Describe the symptoms a little more fully, too, please.
Old Oct 15, 2010 | 09:42 PM
stebbins17's Avatar
stebbins17
it does it at different times like today it did it while i was accelrerating but it was the first time but it mostly does it when i am just cruzing along to describe it best it feels like when you are not giving enough gas for the gear you are in. any cles what it might be.
Old Oct 16, 2010 | 05:06 AM
Guest
Guest
Posts: n/a
It could be a couple of things. When I asked "when" does it do it, I meant more like shortly after startup or after having been ridden for a while, or when it's hot out, or when it's cold out, or...
If it is shortly after startup and/or when it's cold out, then (according to my stealership's mechanics) you aren't warming it up enough. They say that the '07 FI system needs 5 minutes of warmup in order to run correctly in cooler weather, and the bucking and kicking is perfectly normal for inadequate warm up. If it does it at other times, my first guess would be that you are in the wrong gear for the speed you are going, and lugging the engine. Sportster engines like to wind up a bit, and really aren't happy below about 2,500 RPM, especially the FI engines. If neither of these is the case, look for a clogged fuel filter, then check that your fuel pickup hasn't shifted. If all that's good, I'm out of ideas.
Old Oct 16, 2010 | 09:22 AM
stebbins17's Avatar
stebbins17
thanks for the help and yeah yesturday was pretty cold so that could have been what it was.
Old Oct 16, 2010 | 04:10 PM
Guest
Guest
Posts: n/a
Glad I could help. To see if that's the problem, next time it's cold out, warm it up real good before you take off. If it rides right, then you know. If not, it's time to look at tougher fixes.
Old Oct 16, 2010 | 08:55 PM
reconnightster's Avatar
reconnightster
Stage II
Yeah I had the same problem but just give it adequate warmup time, even when its nice outside. My nightster is like a woman, you have to warm her up before you ride her.
Bgelling33
Oct 22, 2012 06:45 PM
damnation9
May 3, 2012 03:55 PM
Clinton350
Sep 22, 2009 09:00 AM
TheEdge
Jul 16, 2008 04:23 PM
dhc8guru
Jul 12, 2007 09:09 PM
