mid/forward pedal switch
Old Nov 1, 2010 | 07:30 AM
thatguy021's Avatar
thatguy021
Default mid/forward pedal switch
does anybody know if the brake pedal for my mid controls will fit my forward controls? somebody was messing with my bike in the parking lot and dropped it. id rather not have to buy a whole new set.
Old Nov 1, 2010 | 09:12 AM
midnight2005's Avatar
midnight2005
try it and find out. I believe it will
Old Nov 1, 2010 | 09:37 AM
hig4s's Avatar
hig4s
It should, and the right side clevis/peg mount on the mids should be the same as both sides on the forwards. I know I just put on my forwards and the left side clevis was mis-drilled so I use the right side clevis from my mids. Can't really tell from the pics, but the clevis from the mids is brushed metal, and the ones that came with the forwards are chrome.
Attached Thumbnails mid/forward pedal switch-cimg0005.jpg   mid/forward pedal switch-cimg0006.jpg
Old Nov 1, 2010 | 07:08 PM
Zimbob's Avatar
Zimbob
They should fit, if not, give E-Bay a try.
I hope you found the scuzzball that was messing with your bike. Make them buy a whole new set.
Old Nov 1, 2010 | 08:38 PM
mreed's Avatar
mreed
I don't think it'll work man. If it mounts up the lever will be horizontal...and you need it to be at something like a 45 degree angle...that may put the clevis in an area where the rod won't connect. If that makes sense...
Old Nov 1, 2010 | 08:58 PM
HarleyScuba's Avatar
HarleyScuba
I'm not gonna say it positivly won't work, but it's probably not a direct bolt-on affair. There may be some large washers involved and/or a twisted rod. Let us know what you find out.
The mid brake pivot point for the brake rod connection is towards the bottom of the brake pedal assembly and at about 45 degress to the brake pedal arm. The forward lever has the pivot on the side, parrallel to the brake pedal arm. The shorter mid brake rod has pivot joints that are nearly perpendicular - the forward's rod ends are parrallel (still, there may be enough flexibility in the heim joints to let it function). The pin for the break lever (top of photo) is longer on the forwards set. You might be able to use the pin from mids to eliminate using large washers. I kinda doubt it'll work.
Mid brake control pictured:
bryon857
Ironhead
20
Jun 11, 2017 10:18 AM
Darkside Dave
Feb 4, 2017 10:35 AM
Jersey Drew
Sep 23, 2014 12:58 PM
bcinva
May 13, 2011 04:28 PM
..but Ill try 2 try
Mar 31, 2006 02:30 PM
