Calling all Dakota digital users
Old Nov 4, 2010 | 06:21 PM
LouEyez's Avatar
LouEyez
Default Calling all Dakota digital users
Hi everyone,
I just got my dd, and I also have the joker machine speedo relocation bracket.
I followed the instructions to the T:
1) removed the 2 screws on the back plate,
2) unplugged the speedo
3) removed it
4) put the Dakota in
5) plugged it
6) put the screws back in
It works
Here is my issue/question
I screwed the screws all the way in, and can't really turn them anymore, but the dd hangs out of the case a tiny bit (from the bottom)
Im pretty sure I replaced the rubber grommet correctly, but I'm not sure.
Has anyone else had this problem and how did you fix this?
Also, is the plug waterproof? Should I be afraid if it rains that water is gonna seep in through that tiny crack and f up everything?
Thanks
L
Old Nov 4, 2010 | 09:15 PM
Chi6er's Avatar
Chi6er
Wink
Loueyez;
I'll be in your boat this weekend. I will installing my gauge on Saturday, I will chime in afterward, whether if I have the same problem or not.
I am not sure how I will set the gear selector, on these busy streets of chicago, I can't see going in 5th gear anywhere.
Jerry
Old Nov 4, 2010 | 09:22 PM
madchemist24's Avatar
madchemist24
Originally Posted by Chi6er
Loueyez;
Jerry
Jerry sounds like its time for a short road trip to the northern burbs .. roads are a bit more open and fun to ride. after you get the lights adjusted head west a bit. i'll break out for a cruise w ya.
Old Nov 5, 2010 | 03:03 AM
LouEyez's Avatar
LouEyez
The Gauge is awesome, and since m,y tank is blue, the blue colors really compliment the bike.
I havent set up the gear selector yet because morning traffic is bee atch but i had my wife drive in front of me today, just to make sure the speedo is on, and it is.
My only worry is this little gap and whether or not I'll be phillipsed if it rains.
L
Old Nov 5, 2010 | 03:06 AM
LouEyez's Avatar
LouEyez
Here is a picture of it
L
Old Nov 5, 2010 | 10:23 AM
Daniel Hunter's Avatar
Daniel Hunter
It looks like something isn't lined up quite right.
I know when I installed mine I had a hard time getting it to sit perfectly in the mount at first. You've got to wiggle it a little back and forth to get it to seat perfectly.
I could be wrong but it doesn't look like yours is sitting in the mount correctly.
Old Nov 5, 2010 | 10:30 AM
sgtt45's Avatar
sgtt45
I had the same problem....there are two rubber seals on the stock and I forgot and only used one. Then went back and installed both rubber seals on the DG.
Old Nov 5, 2010 | 10:45 AM
mattk22's Avatar
mattk22
Where did you guys get your Dakota Digitals from?
Old Nov 5, 2010 | 12:32 PM
Daniel Hunter
I ordered mine direct.
Old Nov 5, 2010 | 03:14 PM
Chi6er's Avatar
Chi6er
Smile
I got my gauge from Phat Performance in California for $359.
Loueyez: did you put both gaskets on?
Jerry
